Intel® High Level Design
722 Discussions
oneAPI Base Toolkit-Error: Compiler Error: OpenCL kernel compile/link FAILED
sent
Hi, I am new to oneAPI and I am trying to ramping up. I installed Intel® oneAPI Base Toolkit and am able to successfully run the vector add sample program in my ubuntu system(Intel Core i5). Then I tried to compile same Vector_Add project for FPGA in emulation mode using below command.
make fpga_emu -f Makefile.fpga
At the time of compilation, I am facing below error.
Error:
dpcpp -fintelfpga src/vector-add.cpp -o vector-add.fpga_emu -DFPGA_EMULATOR
/tmp/vector-add-d62ec6.o: file not recognized: File truncated
clang++: error: fpga compiler command failed with exit code 1 (use -v to see invocation)
clang++: error: linker command failed with exit code 1 (use -v to see invocation)
Makefile.fpga:10: recipe for target 'vector-add.fpga_emu' failed
make: *** [vector-add.fpga_emu] Error 1
Note: I am able to compile with report successfully.
make report -f Makefile.fpga
KennyTan_Altera
Can you try to use Devcloud?
Also, Can you list flow and command you have used?
sent
This issue has been solved. I am able to execute it successfully.
KennyTan_Altera
Great to hear that! Mind to share with us what you have done to resolve this?
KennyTan_Altera
Any update?
sent
Thanks for follow up. I uninstalled the whole set up and reinstalled the same. That resolved the issue.
