Intel® ISA Extensions
Use hardware-based isolation and memory encryption to provide more code protection in your solutions.
A Question about MSR ?
zp_s_
I am a grean-hand,I have a question about msr:when i reboot the computer,will The MSR register reset?or not?,if i write some  infomation to the msr register ,when the cpu reboot ,I need rewrite?
McCalpinJohn
You should assume that all MSRs will be reset to default values on a reboot -- whether it is done by the hardware, by the BIOS, or by the OS.
It is conceivable that there might be an exception, but I can't think of one.
