Intel® ISA Extensions
Use hardware-based isolation and memory encryption to provide more code protection in your solutions.
AVX-512 expectations
capens__nicolas
Announcement: http://software.intel.com/en-us/blogs/2013/avx-512-instructions
What isn't clear from this announcement is whether the future Xeon processor with AVX-512 support will actually be a socketed MIC, or a CPU (more precisely Skylake)? Is it coming to consumer CPUs in a similar timeframe? Developers might want to know, to determine whether to adopt AVX2+ or heterogeneous computing. The latter would benefit the competition more than it would benefit Intel.
SergeyKostrov
Valued Contributor II
Please look for information on the Internet regarding Intel Developer Forum ( IDF ) 2013 event in San Francisco. I think lots of technical details will be provided during the event and after.
Bernard
It seems that combo Xeon cpu and Xeon Phi could be also named heterogeneous computing.
SergeyKostrov
>>... The latter would benefit the competition more than it would benefit Intel. Take a look at latest Intel press releases ( and statements from CEO ) and you will see that Intel is concerned regarding the situation with declining PC sales ( it gets worse and worse every 4 months ) and over-heated competition between Tablet manufacturers.
andysem
New Contributor III
From the published roadmap (e.g. [1]) it looks like AVX-512 is another naming for AVX3.1, which will be present in Knights Landing boards. BTW, if that's correct then Intel should be more consistent about namings - these different flavours of AVX only add confusion for developers. The technology will be refined into AVX3.2 and then released in Skylake CPUs.
Disclaimer: I'm not an Intel representative. The information I have is taken from the public sources and is as reliable as these sources are. Use it at your own discretion.
[1] http://www.tomshardware.com/news/Skylake-Intel-DDR4-PCIe-SATAe,23349.html
capens__nicolas
Indeed, but with a Xeon CPU that supports AVX-512, at least the ISA would be practically homogeneous. With a socketed MIC, it would also be homogeneous architecturally. That could work well for the HPC market.
Personally I'm most interested in consumer CPUs though. Consumer applications are typically real-time, which makes heterogeneous computing very hard due to the overhead of moving data around and scheduling work on different cores through various software layers. With a consumer CPU with AVX-512 support, we could instead instantly switch between scalar and vector code, while the data remains local, thus preserving bandwidth and power.
Since the announcement mentions Sandy/Ivy Bridge and Haswell as part of an evolution to AVX-512 that offers 8x FLOP/sec over (between?) 4 generations, it hints at AVX-512 coming to Skylake. It's not 100% explicit about that though. That said, as far as I know Skylake isn't even officially announced as the successor of Broadwell/Haswell refresh yet, so they might simply want to save that for IDF and be a little vague for now.
capens__nicolas
What are you implying from that regarding AVX-512? I can see two trains of thought: On the one hand AVX-512 could be considered too expensive for an ultra-mobile chip. Haswell's high-power performance is nearly stagnant (for scalar workloads), while massive progress has been made in the low-power department. Intel will have to continue that trend to dominate the market of tablets capable of running a full-fledged desktop O.S. (which is what NVIDIA appears to be aiming for as well with their recently presented mobile Kepler). Silvermont didn't get AVX(2) support, so AVX-512 could be a bridge too far for the architectural successor of Haswell as well.
On the other hand, AVX2 did not seem to significantly impede Haswell from entering the ultra-mobile space from above. For high DLP workloads, wide vectors definitely offer the best performance/Watt. So even for the mobile market it makes sense to support AVX-512, or they'll lose that to various flavors of GPGPU (mobile Kepler, HSA architectures, Mali, etc.). The latter all favor ARM, which is Intel's biggest competition in the mobile market. AVX-512 has to become ubiquitous for x86 and Intel to thrive.
capens__nicolas
As far as I know that's not a published roadmap but rather either a leaked slide or someone's speculation. Interestingly the original presentation (http://www.icsr.agh.edu.pl/~kito/Arch/arch1-1-4B-x86.pdf) mysteriously disappeared...
I think naming it AVX-512 is an attempt at being more consistent. The lack of packed vector instructions for data types smaller than 32-bit shows that it's aimed exclusively at the SPMD programming model. AVX2's closely packed small data types remains somewhat orthogonal to that and is aimed at multimedia where such small data types are common (it is suitable for SPMD as well but lacks dedicated mask registers and such). AVX-512 can have various 'additional' extensions such as exponential and reciprocal instructions. So naming things AVX 3.1 and 3.2 could be more confusing when each support different additional instructions.
Whether or not the AVX-512 name really makes things clearer is debatable. The AVX2 'packed' instructions could be extended to 512-bit in the future, but would no longer be part of the 'AVX-512 foundation'. The SPMD instructions could eventually be extended to 1024-bit and thus be called AVX-1024. Some level of confusion is unavoidable I guess. In any case, low-level programmers (such as compiler developers) shouldn't have a big problem with that, and marketing just wants to stress the greatest width.
andysem
New Contributor III
Well, we have too little information about the extensions to see that. From my mind, it is quite possible that AVX3.2 or whatever it is called in Skylake includes a new set of mask registers and operations that involve them. At the same time, it is also possible that some future instruction extensions will not widen registers and only add new operations (remember SSE-SSE4; also, how would you characterize AVX, which only operates on 256 bit with FP operations but not integer?). If it comes to AVX-512, AVX2-512, The New AVX-512 etc. then I would rather prefer AVX, AVX2, AVX3, AVX4 and so on, regardless of the register width. That, of course, regards to the single product line (general purpose CPUs, in particular). Whether or not names for Xeon Phi extensions match or differ from the GPCPU extensions does not really matter since they don't intersect in any way because are implemented by different classes of products (and physical devices). But, surely, different namings wouldn't hurt in this case and using any form of "AVX" in Xeon Phi extensions certainly doesn't help.
Bernard
>>>but with a Xeon CPU that supports AVX-512, at least the ISA would be practically homogeneous. With a socketed MIC, it would also be homogeneous architecturally. That could work well for the HPC market.>>>
Yep that's true.
With the introduction of 512-bit width AVX extension newest CPU's could compete in terms of raw fp-processing power at single precision with even medium to high-end GPU's.
SergeyKostrov
[ Andysem wrote ] >>... >>Disclaimer: I'm not an Intel representative. The information I have is taken from the public sources and is as reliable >>as these sources are. Use it at your own discretion. >> >>[1] http://www.tomshardware.com/news/Skylake-Intel-DDR4-PCIe-SATAe,23349.html >>... I wouldn't consider it as "actual Intel's roadmap" because a title of the article is Intel Roadmap Post-Haswell Rumour. Also, there is a strange gap between Haswell AVX2 ( 2013 ) and Skylake AVX3.2 ( Future ). So, where are AVX3.0 and AVX3.1 gone? There is just one Broadwell architecture between Haswell and Skylake architectures.
SergeyKostrov
>>...[1] http://www.tomshardware.com/news/Skylake-Intel-DDR4-PCIe-SATAe,23349.html And one more comment on a correctness of the Intel's roadmap pictured: According to the picture ( see above web-link ) Haswell will be released in 2014...
capens__nicolas
Both have perfectly good explanations. The slide shows that Knights Landing supports AVX3.1. The official AVX-512 documentation clarifies that there's a "foundation" of 512-bit instructions, and the possibility of several additional extensions. So the foundation could probably be designated as AVX3.0, and different sets of additional extensions make it AVX3.1 and AVX3.2. If no device supports just the foundation, then AVX3.0 appears to be skipped. A somewhat similar thing happened to SSE4.1 / SSE4.2 / SSE4a.
This is a Xeon roadmap, which explains why Haswell won't be launched until 2014. Note that it is also claimed to support DDR4, which isn't true for currently released desktop/mobile Haswell designs, but matches previous rumours about DDR4 support in the server space.
So in my personal opinion these things don't make this leaked slide less credible.
SergeyKostrov
I will follow up on that subject after IDF 2013 event in San Francisco.
SergeyKostrov
>>...That said, as far as I know Skylake isn't even officially announced as the successor of Broadwell/Haswell refresh yet, so they >>might simply want to save that for IDF and be a little vague for now... This is simply to let you know that Keynotes for IDF 2013 already released and ( I was not surprised ) a word Mobility was used in a Message Subject.
Gregg_S_Intel
Intel® AVX-512 will debut with the many core product code-named "Knights Landing".
Intel AVX-512 will be supported in future Intel® Xeon® processors.
capens__nicolas
Any details on AVX-512 products being presented there?
Bernard
As Sergey said this year IDF was mainly about the mobile platforms.
I attended all those few vector related classes and nothing has been said about the AVX-512.
Bernard
Hi Gregg
Thanks for the explanation but Xeon Phi already has support for 512-bit wide vectors in VPU  unit.So Knights Landing will have another subset of 512-bit wide vector instructions?
capens__nicolas
That's too bad. I understand Intel's current focus on mobile platforms, but the battle between heterogeneous and homogeneous computing is an important one too with huge long-term implications. In my opinion AVX-512 is even a power efficiency feature for high DLP workloads, which will be relevant to the mobile market as well. HSA is a serious contender and could increase the competition from ARMv8 unless developers and system designers have a reason to stick with x86 as their architecture of choice for all computing needs. The best way achieve that is to have a unified x86 architecture which can extract high levels of ILP, DLP and TLP in a compiler-friendly way (thus homogeneous).
capens__nicolas
Unlike the MVEX encoding of current Phi architectures, the EVEX encoding used by AVX-512 allows for other widths than 512-bit. This makes it compatible with AVX-256 and SSE. This strongly hints at AVX-512 coming to a successor of Haswell. The announcement even mentioned Sandy Bridge and Haswell as part of an evolution toward 8X peak FLOP/sec. Still, it only truly confirms that AVX-512 will be feautured in Knight's Landing and some future Xeon processors, which leaves some room for uncertainty especially in the consumer market. I hope that gets clearer up soon.
