Intel® ISA Extensions
Use hardware-based isolation and memory encryption to provide more code protection in your solutions.
AVX trial facility
magicfoot
I would like toconvert and compare my C based SSE code to AVX anddo not yet want to change myrecent non-AVX chipset purchased only in April of this year(2011).
Is there some online facilty where I can do the conversion and comparison. It should not take more than a few days to do this. The C algorithm is academic in nature - EM Modelling.
sirrida
You may download, install and run the Intel Software Development Emulator.
Your program will then be able to use all the new commands, however it will run much slower.
Some additional information after the run such as usage counts is dumped.
You will not be able to perform speed tests.
