Intel® ISA Extensions
Use hardware-based isolation and memory encryption to provide more code protection in your solutions.
AVX2 application released
bronxzv
New Contributor II
As part of the normal updates of our pure software realtime 3D engine
http://www.inartis.com/default.aspx
we have already included a new path forHaswell targets (using FMA and AVX2 instructions).
Thanks to the early support in the Intel compiler and the SDE I was able to port and validate very quickly the codeusing FMA and the 256-bit packed int instructions. A cool feature of the Intel C++ compiler is that legacy code using MUL + ADD intrinsics (such as _mm256_mul_ps / _mm256_add_ps) use FMA instructions wherever possible when compiledwith the "/QxCORE-AVX2" flag, it's a great time saver and we can continue to have exactly the samesourcecodefor all (legacy SSE &AVX andnew FMA+AVX2) paths. Also since we use wrapper classes around intrinsics, the source code is still very readable, for example
res = a*x + b*y +c;
is far more readable than if wehad to introduce FMA functions such as
res = madd(a,x,madd(b,y,c));
More optimization opportunities are still there using any to any permute and gather for example, I suppose that I'll wait for the real chipsfor these.
Max_L
Thank you for your effort and the feedback,it is noticedwith a great pleasure!
