Intel® ISA Extensions
Use hardware-based isolation and memory encryption to provide more code protection in your solutions.
Documentation suggestion
jimdempseyatthecove
This is a suggestion for the documentation relating to SSEn.m
1) Can you add a section that seperates the instructions by type of data. This section would essentially be an index and hyperlinks back to the alphabetical listing. I find it cumbersome to weed through the alphabetical listing.
SSEn.m Instructions by data type
Integer Byte
Integer Word
Integer Double Word
Integer Quad Word
Float
Double
2) Can you addsub-sections under each type in 1) above for functionality
Addition
Subtraction
Boolian
Essentially this is a cross-reference index. I think it would make it much easier to navigate the documentation to find what you want.
Jim Dempsey
SHIH_K_Intel
Integer Byte
Integer Word
Integer Double Word
Integer Quad Word
Float
Double
Addition
Subtraction
Boolian
Jim Dempsey
We'll consider how this type of information can be generated.
