Intel® ISA Extensions
Use hardware-based isolation and memory encryption to provide more code protection in your solutions.
1146 Discussions
Extracting XMM register elements gives compilation error
biplabraut
I have recently started with SIMD and SSE instructions coding. To access individual elements of the 128 bits register, I do like this xml.m128i_i8. But it gives compilation error :-
1>.outline_correct_C.cpp(65): error: union "__m128i" has no member "m128i_i8"
1> if(xm1.m128i_i8)
1> ^
1>
1>.outline_correct_C.cpp(65): error: expression must have class type
1> if(xm1.m128i_i8)
But, I have checked similar uses in the manuals also. Can you please clarify.
With regards.
Nicolae_P_Intel
The __m128i type is definedas the following - please see the emmintrin.h include file
typedef union { char c[16]; } __m128i;
and therefore the error that you get is actuallyOK froma compiler ppoint of view and does not have anything to do with the SSE or SIMD per se.Could you please post your source code so that we can get you started?
Cheers,
Nick
biplabraut
Thanks for your prompt reply.. I was using Intel's Compiler 10.1 with this which was giving this error. But, on using VC++ compiler, it does not give.
levicki
Valued Contributor I
That is because Intel Compiler xmmintrin.h has different definition for __m128i than MSVC compiler.
