Intel® ISA Extensions
Use hardware-based isolation and memory encryption to provide more code protection in your solutions.
Intel Intrinsic Guide (for AVX)
sivanr87
I'm having some problems with the Intel Intrinsic Guide (for AVX).
The downloading is going fine, the problem is with loading the program.
After i download the program and extract it i try to open it through the "Intrinsics Guide for Intel AVX2.exe" link, it start loading and then gets stuck on 100% while loading _mm256_zeroupper.
the link i downloaded from is http://software.intel.com/en-us/avx/.
Thanks for the help,
Sivan.
Michael_K_Intel2
which Java are you running? I had the same problem but version 1.7 u3 with 64bit solved the problem for me. Same version, but 32bit does not work on my machine either with the same behavior that you've described.
Cheers,
-michael
sivanr87
I installed a new version and it worked
Thanks a lot!
Sivan
Patrick_K_Intel
I'll resolve this issue and get a fix out soon.
