Intel® ISA Extensions
Use hardware-based isolation and memory encryption to provide more code protection in your solutions.
1146 Discussions
Introduction to Intel Advanced Vector Extensions
bronxzv
New Contributor II
I just read this article:
http://software.intel.com/en-us/articles/introduction-to-intel-advanced-vector-extensions/
it's a fairly good introduction to AVX though in the "Instruction Set Overview"the author states that "As a result, the VEX instructions can only be used when running in 64-bit mode." I know from first hand experience that this is wrong since my own AVX coderunfine in32-bit mode on a Sandy Bridge CPU. I'll suggest to fix this error in the article since newcomers to AVX may be misled by this.
Max_L
nice catch, wrong statement for sure, we will fix it, thanks! ... author was close in understanding of LDS/LES opcodes re-use for VEX prefix, but what happens in 32-bit is that VEX prefix, although still using LDS/LES opcodes, always ends up in unsupported forms of these instructions (those with memory operands), thanks to bit-complement encoding of some fields, hence everything is backwards compatible in 32-bit mode too
-Max
