Intel® ISA Extensions
Use hardware-based isolation and memory encryption to provide more code protection in your solutions.
1137 Discussions
Is there some instruction to do shift to left by the number from mask register somehow?
denbianh
Hi experts,
Now I want a process like psllw(d/q) behavior, but COUNT can be unequal for each word(dword/qword etc).
How can I do that, any instruction or instruction pairs can be use?
Appreciate if you can give me some tips/hints.
Thank you in advance.
-Steven
denbianh
Here I will provide the sample to make this question much clearer: Assume Bi (0-7) for Byte(s) in some xmm0 register in LSB, xmm0 = 00 00 00 00 00 00 00 00 B7 B6 B5 B4 B3 B2 B1 B0 How can I get desired result? like, xmm1 = (B7<<7) (B6<<6) (B5<<5) (B4<<4) (B3<<3) (B2<<2) (B1<<1) (B0<<0) Thanks.
sirrida
Let me propose to simulate the shifting via PMULLW (SSE 2) or PMULLD (SSE 4.1) as a poor replacement. When AVX2 becomes available you can apply the commands VPSLLVD and VPSLLVQ. Alternatively AMD provides the commands VPSHL(B/W/D/Q) with their new XOP commands.
denbianh
Thanks Sirrida for your answer here. It is very valuable for me to follow this.
