Intel® ISA Extensions
Use hardware-based isolation and memory encryption to provide more code protection in your solutions.
Leakage or Static power of a processor
gokussj9
初學者
2,380 檢視
I am using an Intel Xeon 5500 in my desktop.
Does anyone know how to determine the static or leakage power consumption of the
processor? Is there any documentation on it that can at least tell me its range in watts?
Thank You
0 積分
3 回應
TimP
榮譽貢獻者 III
2,380 檢視
I believe these can vary significantly within the specs, and may or may not be significantly lower than the max spec. Obviously, the CPU is only a small part of the total.
Nicolae_P_Intel
2,380 檢視
you can find the specs on ark.intel.com.
what OS are you running?
are you interested in power saving features of your CPU?
btw... you could measure the power usage of your entire system with an externalpower meter.
what exactly are you after?
gokussj9
初學者
2,380 檢視
I am working on Ubuntu 9.10 yeah, I am doing research in power and energy optimization.
I have a wattsup pro power meter by which I can measure the whole system power and power on
different frequencies. I just want to know the static power consumption somehow.
回覆
