Intel® ISA Extensions
Use hardware-based isolation and memory encryption to provide more code protection in your solutions.
1152 Discussions
MASM files + Intel compiler/assembler in Linux
chekib
I have done some evaluation tests of intel compiler and I want to use it to compile my C code in both windows and Linux plateforms. My code has some assembly files written in MASM syle as well.
I am wondering if intel compiler does support assembly files (MASM style) ,originally written/debugged in windows with intel compiler, in Linux ?
My problem is that I don't want to rewrite the MASM files to be compatible with the intel toolchain in Linux.
Other question:
In windows, Visual Studio 2010, intel compiler 12 seems to use actually ML.exe and ML64.exe to assemble .asm file. why intel does not have their own assembler, using ML/ML64, does it hurt overall performance?
--Chekib
SergeyKostrov
Valued Contributor II
Note: this is a Duplicate and please follow a Mainthread at:
http://software.intel.com/en-us/forums/showthread.php?t=106539&o=a&s=lr
