Intel® ISA Extensions
Use hardware-based isolation and memory encryption to provide more code protection in your solutions.
1146 Discussions
Need help with intel software development emulator
Tenuko35
I downloaded intel sde from the official website and extracted it using winrar and when i try to run sde it just opens for a second and then closes. I even tried to extract it using 7zip and also tried to run as administrator but it nothing works. Can anyone help me
AdyT_Intel
Do you use cygwin? you can try running chmod +x on all the SDE files extracted from the kit.
