Intel® ISA Extensions
Use hardware-based isolation and memory encryption to provide more code protection in your solutions.
1147 Discussions
Possible error in Software Developer’s Manual
Yeager__David1
I'm referring to this document:
Intel® 64 and IA-32 Architectures
Combined Volumes:
1, 2A, 2B, 2C, 2D, 3A, 3B, 3C, 3D and 4
Order Number: 325462-072US
May 2020
There looks to be an error in the instruction operand encoding descriptions when either VEX or EVEX can be used with the same instruction. For example, take a look at the instruction description for GF2P8AFFINEQB on page Vol. 2A 3-445
In the Instruction Operand Encoding table, second row for Op/En B, the entry for the Operand 2 column should say VEX.vvvv (r), not EVEX.vvvv (r) as it currently is written, since the B encoding is for AVX/VEX, not AVX512/EVEX.
This error is repeated throughout many instructions in this manual.
Can you please confirm that this is an error? I'm adding support for these encodings to our compiler and need to verify this.
David Yeager
MarkC_Intel
Thanks. I'll pass this  along to our documentation team.
