Intel® ISA Extensions
Use hardware-based isolation and memory encryption to provide more code protection in your solutions.
Problem with _mm_load_si128
pranith
Hi, I am having trouble when I use the _mm_load_si128 intrinsic on Intel 3770k processor.
__m128i packed_image128 = _mm_load_si128((__m128i*)packed_image);
Is causing a seg fault on this processor with both icpc 13.0 and g++ 4.6.3. I made sure that packed_image is 16 byte aligned.
My flags are -march=native -O0 -g -msse4.2. This works fine if compiled using -O2.
Any ideas on how I can proceed on this?
SergeyKostrov
Valued Contributor II
Hi everybody, >>... >>My flags are -march=native -O0 -g -msse4.2. This works fine if compiled using -O2. >> >>Any ideas on how I can proceed on this? >>... I tried to reproduce it on a Windows platform without success ( sorry, I don't have a Linux ) and I think the thread has to be moved to Intel C++ compiler forum. My test-case was as follows: ... _RTUNALIGN RTbyte packed_imageU[128] = { 0x1, 0x1, 0x1, 0x1 }; __m128i packed_image128U = _mm_loadu_si128( ( __m128i * )packed_imageU ); // No Problems _RTALIGN16 RTbyte packed_imageA[128] = { 0x2, 0x2, 0x2, 0x2 }; __m128i packed_image128A = _mm_load_si128( ( __m128i * )packed_imageA ); // No Problems ... [ To Pranith ] How did you declare 'packed_image' variable?
pranith
This works currently with 13.0.1. Thanks!
SergeyKostrov
>>...This works currently with 13.0.1... What is it fixed with the latest Intel C++ compiler update? Anyway, thank you for the update.
