Intel® ISA Extensions
Use hardware-based isolation and memory encryption to provide more code protection in your solutions.
QPI will abort TSX transactions?
Oliver_K_
On a system with at least two NUMA nodes - will an accessing cache-lines from another NUMA node (through QPI) abort a RTM/HLE transaction?
I can't find a hint in the Intel documentation.
AFAIK, TSX uses the cc-snoop protocols so I would assume that the snoop protocol messages are not passed through the QPI.
With which error is the transaction aborted? With capacity error or memory confilct ...?
best regards,
Oliver
