Intel® ISA Extensions
Use hardware-based isolation and memory encryption to provide more code protection in your solutions.
RTM/HLE abort on stack pointer mod
Oliver_K_
to be confirmed: modification on stack pointer register (RSP/ESP) will not abort HLE/RTM?!
ty,
Oliver
James_C_Intel2
Of course it won't abort.  It's just a register like any other from the TSX hardware's point of view.
(If you couldn't modify it you'd be unable to use the call or ret instructions inside a speculative region!)
Oliver_K_
I assume the same is true for exchanging the complete stack (e.g. assigning address from a complete different address range than the current one points to).
James_C_Intel2
As before : " It's just a register like any other from the TSX hardware's point of view." So you can put whatever you like into it, and the hardware doesn't care.
jimdempseyatthecove
James,
While changing the content of the stack pointer would not terminate the transaction, using the stack could when the access causes a page fault. This may be relatively rare after the first use of the specific page(s) of stack address space.
Jim Dempsey
James_C_Intel2
Of course, but so could any memory access, so I see that as a different concern.
