Intel® ISA Extensions
Use hardware-based isolation and memory encryption to provide more code protection in your solutions.
SDE segfaults when running the JVM
JosefEisl
Hello!
I noticed that SDE is not able to execute the JVM:
$ java -version
openjdk version "11.0.14.1" 2022-02-08
OpenJDK Runtime Environment 18.9 (build 11.0.14.1+1)
OpenJDK 64-Bit Server VM 18.9 (build 11.0.14.1+1, mixed mode, sharing)
$ ~/Downloads/sde-external-9.0.0-2021-11-07-lin/sde64 -- java -version
Segmentation fault (core dumped)
 I know that the VM is using SEGFAULT handlers for implicit null checks, which is not supported according to the SDE FAQ, but for --version I'd assume that this is not the issues as not Java program is executed.
Any ideas how to find out what is causing the issue?
Thanks, Josef
AdyT_Intel
Fedora 35 is using a new system call (clone3) and the support for it still does not exists in the latest external Intel SDE version (9.0).
This will be fixed in the next release.
AdyT_Intel
Please provide more details on your system.
I tried running Java from openjdk 17.0.2 and openjdk version 1.8.0 on my Ubuntu 20.04 host and both pass with no issue.
% sde-external-9.0.0-2021-11-07-lin/sde64 -- ./jdk-17.0.2/bin/java -version
openjdk version "17.0.2" 2022-01-18
OpenJDK Runtime Environment (build 17.0.2+8-86)
OpenJDK 64-Bit Server VM (build 17.0.2+8-86, mixed mode, sharing)
JosefEisl
Thanks for the quick reply!
Interesting! I'm on Fedora 35, openjdk installed via the package manager:
Installed Packages
Epoch : 1
Version : 11.0.14.1.1
Release : 5.fc35
Architecture : x86_64
Source : java-11-openjdk-11.0.14.1.1-5.fc35.src.rpm
Repository : @system
From repo : updates
Summary : OpenJDK 11 Runtime Environment
URL : http://openjdk.java.net/
License : ASL 1.1 and ASL 2.0 and BSD and BSD with advertising and GPL+ and GPLv2 and GPLv2 with exceptions and IJG and LGPLv2+ and MIT and MPLv2.0
: and Public Domain and W3C and zlib and ISC and FTL and RSA
Description : The OpenJDK 11 runtime environment.
AdyT_Intel
JosefEisl
Good to know! Thanks for the update and looking forward to the next release!
Thanks, Josef
