Intel® ISA Extensions
Use hardware-based isolation and memory encryption to provide more code protection in your solutions.
1138 Discussions
Software Development Emulator on windows WSL2 (ubuntu 20)
stef77
I'm trying to use the SDE on windows WSL2 (Ubuntu 20) but it doesn't work. The sde is not recognized has a command. I set the execution privilegies to sde.
I looked for the /proc/sys/kernel/yama/ptrace_scope but yama is not present in my ubuntu version.
Do you have any suggestions how to proceed?
AdyT_Intel
Did you try running sde64?
The sde command line tool is 32 bits binary capable of running both 32 and 64 bits workloads, but it requires the 32 bits runtime in the system. The sde64 tool is intended to be used on 64 bits only systems.
stef77
After restarting WSL2 and applyiing execution privilegies on the SDE folder the sde64 worked. Thanks
