Intel® ISA Extensions
Use hardware-based isolation and memory encryption to provide more code protection in your solutions.
Sorting an array of 128bits keys
Jerome_M_Intel
My master plan is all thwarted... The data I need to sort fits quite nicely in one 64 bits and two 32 bits values. They're all positive and their encoding is such that they can be sorted as if they were one big 128 bits integer. It was all planned from the start so that I could load'em straight to SSE registers, do some easy comparison work and get the sorting done in the blink of an eye. Unfortunately, without the ability to compare unsigned integers values, I end up with this code as my best guess:
[cpp]
    bool isLess(const sDisplayItem &A, const sDisplayItem &B)
    {    /* TODO: there should be a faster way... */
        int ab,ba;
        __m128i mX = _mm_set1_epi32( 0x80000000 );
        __m128i mA = _mm_sub_epi32( _mm_load_si128( (__m128i *)&A), mX); /* make values signed */
        __m128i mB = _mm_sub_epi32( _mm_load_si128( (__m128i *)&B), mX); /* make values signed */
        __m128i AB = _mm_cmplt_epi32(mA, mB);
        __m128i BA = _mm_cmpgt_epi32(mA, mB);
        ab = _mm_movemask_ps(_mm_castsi128_ps(AB));
        ba = _mm_movemask_ps(_mm_castsi128_ps(BA));
        return ab>ba;
[/cpp]
Anybody ran into a similar situation before, any trick to share ? Thanks
Jerome_M_Intel
A simpler version was found, using SSE4. But is this the best way?
[cpp]
		int ab,ba;
		__m128i mA = _mm_load_si128( (__m128i *)&A);
		__m128i mB = _mm_load_si128( (__m128i *)&B);
		__m128i mC = _mm_min_epu32(mA, mB);
		__m128i AB = _mm_cmpeq_epi32(mA, mC);
		__m128i BA = _mm_cmpeq_epi32(mB, mC);
		return ab>ba;
[/cpp]
