Intel® ISA Extensions
Use hardware-based isolation and memory encryption to provide more code protection in your solutions.
Understanding Bitwise Intrinsics
YAkha
This is a very simple doubt, but I just started out with AVX512 ISA.
_mm512_xor_epi64 This intrinsic needs two _m512i data types, which i am let to believe are packed with 8 int64 values each.  And this command will return a _m512i data type containing 8 integers which are the result of the bitwise logical XOR operation between each of the 8 integers.
For instance, if the _m512i A data type is packed with (2,1,4,5,2,2,3,1) int64 values, and _m512i is packed with (4,2,1,3,5,2,1,3).
Then running _mm512_xor_epi64(A, B) will return a pointer to a _m512i data type which contains (xor(2,4), xor(1,2), xor(4,1), xor(5,3), xor(2, 5), xor(2, 2), xor(3, 1), xor(1,3)). Where xor() is the bitwise XOR of the binary form of 2 and 4, isnt it?
Does extern __m512i __cdecl _mm512_load_epi64(void const* mt); Does this allow me to pack an allocated array of 8 int64 values into a _m512i data type, provided * mt is the pointer to such an array?
Is there an intrinsic to unpack such values? Would really appreciate some help in the right direction.
andysem
New Contributor III
No, it will return the vector by value.
That's right.
The _mm512_load_epi64 intrinsic loads a vector from aligned memory. "Packing" is not the right term because there are a number of pack/unpack intrinsics which operate differently.
Assuming you want to extract elements of a vector, there are a number of extract intrinsics (https://software.intel.com/sites/landingpage/IntrinsicsGuide/#text=extract). Depending on the circumstances, there might be other ways, like storing the vector to memory first or shuffling the elements (https://software.intel.com/sites/landingpage/IntrinsicsGuide/#text=shuffle) and then extracting the lowest element (https://software.intel.com/sites/landingpage/IntrinsicsGuide/#text=cvt&expand=1810&techs=SSE,SSE2).
andysem
New Contributor III
That's right.
