Intel® ISA Extensions
Use hardware-based isolation and memory encryption to provide more code protection in your solutions.
1152 Discussions
Vectorization - pragma asm interpretation
srimks
New Contributor II
Simply looking to interpret below things -
(a) For multiple C++ package file, when I do vectorizations (calling of pragma's) within that file within section of code, I get starting and ending asm as -
44d960: 55 push %rbp
44d961: 48 83 ec 50 sub $0x50,%rsp
44d965: 49 89 f0mov %rsi,%r8
44d968: 4c 63 c9movslq %ecx,%r9
44dc84: 48 83 c4 50 add $0x50,%rsp
44dc88: 5dpop %rbp
44dc89: c3retq
44dc8a: 90 nop
44dc8b: 48 8d 74 26 00 lea 0x0(%rsi),%rsi
(b) But the same code w/o using any pragma's call, the starting & ending asm are as -
44d960: 48 83 ec 68 sub $0x68,%rsp
44d964: 49 89 f9mov %rdi,%r9
44d967: 49 89 d0mov %rdx,%r8
44d96a:4c 63 d1movslq %ecx,%r10
44dc4e: 48 83 c4 68add $0x68,%rsp
44dc52: c3retq
44dc53: 90nop
44dc54: 48 8d 74 26 00lea 0x0(%rsi),%rsi
44dc59: 48 8d bf 00 00 00 00lea 0x0(%rdi),%rdi
Query:
(1) Could the difference between having PUSH/POP call with pragma vectorization calls and not having w/o it be differentiated?
(2) W/o pragma calls, the asm in (b) has "lea" calls twice and also the during starting it has - sub, mov, mov & movslq than with pragma calls, why pragma calls bring such a difference?
~BR
levicki
Valued Contributor I
Two LEA instructions at the function end are simply fillers (NOPs) to ensure proper alignment for the next function -- they aren't part of the function epilogue.
As for the prologue difference it is hard to tell without seeing the rest of the surrounding code. Most likely vectorization enables the compiler to "see" an opportunity for some other optimizations thus resulting in a bit shorter code which uses less variables.
srimks
New Contributor II
Quoting - Igor Levicki
yeah, you are right for epilogue, code-generators normally generates NOP (no-operation) instructions to align instructions.
Lets look for prologue part if possible.
Thanks Igor.
~BR
srimks
New Contributor II
As qouted "As for the prologue difference it is hard to tell without seeing the rest of the surrounding code. Most likely vectorization enables the compiler to "see" an opportunity for some other optimizations thus resulting in a bit shorter code which uses less variables.", probably iif you see prologues of both -
(a) Prologue with pragma vectorization -
44d965: 49 89 f0 mov %rsi,%r8
(b) The same code w/o using any pragma's call, the prologue asm are as -
44d964: 49 89 f9 mov %rdi,%r9
44d967: 49 89 d0 mov %rdx,%r8
44d96a:4c 63 d1 movslq %ecx,%r1
With above (a) i.e with pragma, the "PUSH %RBP" instructions is internally split into two micro-operations which can be represented as "SUB RSP, 4" and "MOV [RDI], %r9" . The advantage of this is that the "SUB RSP, 4" micro-operation can be executed even if the vale of RBP is not ready yet.
I don't think much gain can be obtained with both the prologues with and w/o pragma vectorization, their meanings are same, the only important factor which makes a difference is having "lea" instructions twice for alignment with pragma call of vectorization.
But the questions arises - why the "sub $0x68,%rsp" & "mov %rdi,%r9" w/o pragma have been replaced with single "push %rbp"?
is it becoz "push %rbp" has better latency and reciprocal throughput.
~BR
