Intel® ISA Extensions
Use hardware-based isolation and memory encryption to provide more code protection in your solutions.
1138 Discussions
What is ENQCMD/MOVDIR64B submission latency in Intel Data Streaming Accelerator
yslys
Hi all,
I would like to know in detail about the submission latency of ENQCMD/MOVDIR64B instruction for submitting 64-byte work descriptors in the context of Intel Data Streaming Accelerator. Based on what I know, it is a non-posted 64-byte MMIO write, so theoretically it should be around tens of nanoseconds.
However, I found this paper: @ https://arxiv.org/pdf/2305.02480, in which Figure 5 indicates that the submission latency is around 5us. I think this is too slow compared to a normal MMIO write. That is why I am confused.
Could anyone please tell me what is the latency starting from user issuing the instruction ENQCMD/MOVDIR64B to the device actually received the 64B work descriptor? May I know if around 17ns is a reasonable estimate? If not, what is a reasonable estimate?
Thanks in advance!
