Intel® ISA Extensions
Use hardware-based isolation and memory encryption to provide more code protection in your solutions.
1143 Discussions
Why AVX code slower then native C++ code ?
Jorn_V_
Good day, dear experts.
I have the following AVX and Native codes:
__forceinline double dotProduct_2(const double* u, const double* v)
	_mm256_zeroupper();
	__m256d xy			= _mm256_mul_pd(_mm256_load_pd(u), _mm256_load_pd(v));
	__m256d temp		= _mm256_hadd_pd(xy, xy);
	__m128d dotproduct	= _mm_add_pd(_mm256_extractf128_pd(temp, 0), _mm256_extractf128_pd(temp, 1));
	return dotproduct.m128d_f64[0];
__forceinline double dotProduct_1(const D3& a, const D3& b)
	return a[0] * b[0] + a[1] * b[1] + a[2] * b[2] + a[3] * b[3];
And respective test scripts:
	std::cout << res_1 << " " << res_2 << " " << res_3 << '\n';
		std::chrono::high_resolution_clock::time_point t1 = std::chrono::high_resolution_clock::now();
		for (int i = 0; i < (1 << 30); ++i)
			zx_1 += dotProduct_1(aVx[i % 10000], aVx[(i + 1) % 10000]);
		std::chrono::high_resolution_clock::time_point t2 = std::chrono::high_resolution_clock::now();
		std::cout << "NAIVE : " << std::chrono::duration_cast<std::chrono::milliseconds>(t2 - t1).count() << '\n';
			zx_2 += dotProduct_2(&aVx[i % 10000][0], &aVx[(i + 1) % 10000][0]);
		std::cout << "AVX : " << std::chrono::duration_cast<std::chrono::milliseconds>(t2 - t1).count() << '\n';
	std::cout << math::min2(zx_1, zx_2) << " " << zx_1 << " " << zx_2;
Well, all of the data are aligned by 32. (D3 with __declspec... and aVx arr with _mm_malloc()..)
And, as i can see, native variant is equal/or faster than AVX variant. I can't understand it's nrmally behaviour ? Because i'm think that AVX is 'super FAST' ... If not, how i can optimize it ? I compile it on MSVC 2015(x64), with arch AVX. Also, my hardwre is intel i7 4750HQ(haswell)
James_C_Intel2
It's impossible to say without more information.
  • What optimisation flags are you giving the compiler?
  • Can you dump the assembly code generated by the compiler?
Without looking at the assembly code we can't know for sure that you're not comparing your intrinsics code with vectorized code that the compiler has managed to do more with (unroll and pipeline, for instance).
