Hello, all.
I am trying to encode mov and call instruction on CentOS7, but encountered some error.
The source code is as below.
#ifdef __X86_64__
#define XED_MMODE XED_MACHINE_MODE_LONG_64
#define XED_STACK_ADDR_WIDTH XED_ADDRESS_WIDTH_64b
#else
#define XED_MMODE XED_MACHINE_MODE_LEGACY_32
#define XED_STACK_ADDR_WIDTH XED_ADDRESS_WIDTH_32b
#endif
static xed_uint8_t ret_inst[MAX_INST_LEN_X86_64];
static unsigned ret_inst_len;
static xed_uint8_t load_func_inst[MAX_INST_LEN_X86_64];
static unsigned load_func_inst_len;
static xed_uint8_t call_mem_acc_handler_wrapper_inst[MAX_INST_LEN_X86_64];
static unsigned call_mem_acc_handler_wrapper_inst_len;
__attribute__((constructor)) static void __init_inst(void){
xed_encoder_instruction_t enc_inst;
xed_encoder_request_t enc_req;
xed_error_enum_t xed_err;
xed_state_t dstate = {XED_MMODE, XED_STACK_ADDR_WIDTH};
//RET instruction
xed_inst0(&enc_inst, dstate, XED_ICLASS_RET_NEAR, 0);
xed_encoder_request_zero_set_mode(&enc_req, &dstate);
if(unlikely(!xed_convert_to_encoder_request(&enc_req, &enc_inst))){
fprintf(stderr, "conversion to encode request failed\n");
abort();
xed_err = xed_encode(&enc_req, ret_inst, sizeof(ret_inst) , &ret_inst_len);
if(unlikely(xed_err != XED_ERROR_NONE)){
fprintf(stderr, "xed encoding request of `ret` failed : XED error number(%d)\n", xed_err);
abort();
//function address LOAD instruction "mov *mem_acc_handler_wrapper,(%rsp)"
xed_uint64_t fa = mem_acc_handler_wrapper;
xed_encoder_operand_t faddr_oper = xed_imm0(fa, __SIZEOF_POINTER__);
xed_encoder_operand_t m_oper = xed_mem_bd(XED_REG_RSP, xed_disp(0,32), 64);
xed_inst2(&enc_inst, dstate, XED_ICLASS_MOV, 0, faddr_oper, m_oper);
abort();
xed_err = xed_encode(&enc_req, load_func_inst, sizeof(load_func_inst) , &load_func_inst_len);
fprintf(stderr, "xed encoding request of `mov` failed : XED error number(%d)\n", xed_err);
abort();
//CALL instruction "call *(%rsp)"
xed_inst1(&enc_inst, dstate, XED_ICLASS_CALL_NEAR, 0, xed_mem_bd(XED_REG_RSP, xed_disp(0,8), 0));
abort();
xed_err = xed_encode(&enc_req, call_mem_acc_handler_wrapper_inst, sizeof(call_mem_acc_handler_wrapper_inst) , &call_mem_acc_handler_wrapper_inst_len);
fprintf(stderr, "xed encoding request of `call` failed : XED error number(%d)\n", xed_err);
abort();
Calling this function, I got the following message and my program stopped.
xed encoding request of `mov` failed : XED error number(2) # 2 means "XED could not decode the given instruction".
中止 (コアダンプ) #core dump by abort()
I have no idea about what happened.
And I cannot Identify a source of the problem because of few documentation of Intel® XED.
I would appreciate if you would help me about this error.
- Tags:
- Intel® Advanced Vector Extensions (Intel® AVX)
- Intel® Streaming SIMD Extensions
- Parallel Computing
I'm not familiar with XED, and I'm not sure how to interpret the "mov *mem_acc_handler_wrapper,(%rsp)" comment. I'm guessing you're trying to store a 64-bit immediate value to stack. If so, the problem you're having is likely caused by the fact that there is no such mov instruction in x86. Only 32-bit and smaller immediates can be stored directly into memory. You have to first load the 64-bit immediate value into a register using a dedicated mov and then store that register to the stack.
Dear andysem,
Thank you for the reply.
As you guessed, mem_acc_handler_wrapper is a function and 64-bit immediate value.
On reading your comment, I changed the code at line 40 as below, in order that value of mem_acc_handler_wrapper is stored in the %rax register. However, I got the same massage.
//"mov mem_acc_handler_wrapper,%rax" where mem_acc_handler_wrapper is an immediate value. xed_inst2(&enc_inst, dstate, XED_ICLASS_MOV, 0, faddr_oper, xed_reg(XED_REG_RAX));
After that, I modified the code as below to confirm whether a mov instruction containing an immediate value is invalid. However, even in this case, I got the same error message.
//"mov %r10,%rax" xed_inst2(&enc_inst, dstate, XED_ICLASS_MOV, 0, xed_reg(XED_REG_R10), xed_reg(XED_REG_RAX));
Although something except for xed_* functions seems to be wrong, there is no other difference between encoding RET and MOV.
In addition the above, I found that an example in the official package (available at https://software.intel.com/en-us/protected-download/267266/560870/step2) dose not work correctly. The error message is as follows.
~/source/xed-install-base-2016-02-02-lin-x86-64/examples$ ./xed-ex5-enc ENCODE ERROR: GENERAL_ERROR ENCODE ERROR: GENERAL_ERROR Result: 2 03 82 44 33 22 11 add eax, dword ptr [edx+0x11223344] Result: 3 64 03 84 b0 44 33 22 11 add eax, dword ptr fs:[eax+esi*4+0x11223344] ENCODE ERROR: GENERAL_ERROR ENCODE ERROR: GENERAL_ERROR ENCODE ERROR: GENERAL_ERROR ENCODE ERROR: GENERAL_ERROR ENCODE ERROR: GENERAL_ERROR ENCODE ERROR: GENERAL_ERROR ENCODE ERROR: GENERAL_ERROR Result: 11 f3 48 ae rep scasb byte ptr [rdi] ENCODE ERROR: GENERAL_ERROR ENCODE ERROR: GENERAL_ERROR ENCODE ERROR: GENERAL_ERROR ENCODE ERROR: GENERAL_ERROR Result: 16 48 83 c0 77 add rax, 0x77 Result: 17 48 05 11 22 33 44 add rax, 0x44332211 ENCODE ERROR: GENERAL_ERROR ENCODE ERROR: GENERAL_ERROR ENCODE ERROR: GENERAL_ERROR Result: 21 7c 05 jl 0x7 Result: 22 67 7c 05 addr32 jl 0x8 Result: 23 78 05 js 0x7 ENCODE ERROR: GENERAL_ERROR
Therefore, I concluded Intel XED is not reliable. If you do not agree with me, I ask you to tell me your idea.
