Intel® ISA Extensions
Use hardware-based isolation and memory encryption to provide more code protection in your solutions.
1138 Discussions
ambiguity whether VGF2P8MULB supports memory fault suppression
Beulich__Jan
The text says so, but the exception specification says E4NF (ISA extensions doc rev 035). Could this be clarified here and corrected there, please? Thanks1
MarkC_Intel
Hey Jan,
I will try to get the doc fixed. The EVEX encoded versions do support memory fault suppression and should be listed as type E4.  The Legacy and Vex encoded versions obviously do not have masking so they don't have memory fault suppression either. The vex version is  "Type 4". And the legacy versions will need a some text added.
Mark
