Intel® ISA Extensions
Use hardware-based isolation and memory encryption to provide more code protection in your solutions.
how aligned class data member,
Timocafe
Hello All,
I am implemented a unlimited integer class, and I used SIMD to calculate basic operation + *.
At the beginning I developed a single kernel to test my code, and I declared and aligned my data
in the main by the __attribute__((aligned(16))) command, it works. Now I am writing
a basic class, nevertheless the command__attribute__((aligned(16))) does not align (why) my array
and so the code crash when I run it.
Any idea to align a basic array on 16 bytes boundary as data member of a class.
Tim
Matthias_Kretz
note that __attribute__((aligned(16))) only works for allocation on the stack. When you allocate a type defined with that attribute on the heap (i.e. new/malloc) then the alignment restriction of the attribute does not apply. Instead you should rather use _mm_malloc with the correct alignment parameter.
It is possible to overload the new and delete operators of the class to achieve the desired effect automatically:
void *operator new(size_t size) { return _mm_malloc(size, alignment); }
void *operator new[](size_t size) { return _mm_malloc(size, alignment); }
void operator delete(void *ptr, size_t) { _mm_free(ptr); }
void operator delete[](void *ptr, size_t) { _mm_free(ptr); }
Nicolae_P_Intel
could you please re-check your post?your question is somehow missing (or not displayed properly).
Timocafe
Done, I do not why it does not work the first time !
Timocafe
I find I make a typo on my kernel, sorry.
Nicolae_P_Intel
can you share what typo have you find?
what compiler are you using and which platform? 64 or 32 bit?
what compiler options?
Matthias_Kretz
Timocafe
Thank you very much for these informations, I did not know about __attribute__((aligned(16))) runs only in the stack. No problem to overload the operator, great solution !
Thank you
Tim
Gaiger_Chen
By the way, if your platform is windows , use :
_aligned_malloc / _aligned_free
to allocate aligned memory.
Matthias_Kretz
If you can use _mm_malloc, then please don't use windows specific API for the sake of portability. The only real standard way of allocating aligned memory on the heap probably is posix_memalign (sadly Windows doesn't offer POSIX compat per default, though). So using the _mm_ intrinsics probably comes closest to a portable standard...
Gaiger_Chen
Hi
quick solution : use
_mm_loadu_si128 / _mm_storeu_si128
to replase
_mm_load_si128 and _mm_store_si128
it should be pass.
(the __attribute__((aligned(16))) could be remove also.)
