Intel® ISA Extensions
Use hardware-based isolation and memory encryption to provide more code protection in your solutions.
1138 Discussions
how to display output in sse intrinsic codes
Smart_Lubobya
i seem to have trouble in using the cout << output code: here are my codes, please help
#include "stdafx.h"
#include
#include
#include
#include
#include
#include
using namespace std;
int _tmain(int argc, _TCHAR* argv[])
int j;
__m128 s0, s1, s2, s3;
__declspec(align (16))float block[4][4]={1,1,1,1,2,2,2,2,3,3,3,3,4,4,4,4};
for(j = 0; j < 16; j += 4)
__m128 v = _mm_load_ps(block);
__m128 w = _mm_load_ps(block[j+1]);
__m128 x = _mm_load_ps(block[j+2]);
__m128 y = _mm_load_ps(block[j+3]);
s0 = _mm_add_ps(v,y);
s3 = _mm_sub_ps(v,y);
s1 = _mm_add_ps(w,x);
s2 = _mm_sub_ps(w,x);
cout << s0 << endl;//error C2679: binary '<<' : no operator found which takes a right-hand operand of type '__m128' (or there is no acceptable conversion)
return 0;
bronxzv
New Contributor II
here is one implementation of operator << for quad floats that you can usein your project :
ostream & operator << (ostream &out, const __m128 &m)
float v[4]; _mm_storeu_ps(v,m);
out << v[3] << " | " << v[2] << " | " << v[1] << " | " << v[0];
return out;
it's a simple, albeit valuable tool for learning these things or to debug your code
btw there is a bug in your loop, it should be :
for (int j=0; j<4; j++)
isn't it?
kaletinkle
#include "stdafx.h"
#include
#include
#include
#include
#include
#include
int j;
return 0;
return out;
Smart_Lubobya
after puting the output codes i now get the error
#include "stdafx.h"
#include
#include
#include
#include
#include
#include
int j;
{ //error C2601: 'operator <<' : local function definitions are illegal
return out;
please i want to see the output s0,s1,s2 and s3. help
bronxzv
New Contributor II
Smart, you must (obviously?) declarethe__m128 operator << freefunction before"_tmain"
Then you can write thinks like : cout << "s0 = " << s0 << " s1 = " << s1 << endl;
Please also note my fix for your buggyloopcontrol in my old post
