Intel® ISA Extensions
Use hardware-based isolation and memory encryption to provide more code protection in your solutions.
1138 Discussions
why the simulation of linear address masking is not working?
ciyan
My sde version is 2024-01-07 version 9.33.
and the command is "./sde64 -future -lam 1 -- cpuid | grep LAM"
But the output is
LAM: linear address masking = false
May I ask if there was an error in my running command or if the current version does not support LAM? If it is due to version issues, can you provide me with version 8.63 of 2021-01-18, which seems to be a version that supports LAM
Thank you veryvery much for sparing your valuable time.
AdyT_Intel
The LAM support is present but we failed to update the CPUID info regarding LAM.
We will add it in the next Intel SDE release.
The address masking (of LAM) should work when the LAM knob is set.
