Intel® ISA Extensions
Use hardware-based isolation and memory encryption to provide more code protection in your solutions.
zeroing idioms with APX
Beulich__Jan
May I ask whether at this relatively early stage it is already clear which APX insn forms are going to be treated as zeroing idioms? For REX2-prefixed ones I assume there'll be no difference to other legacy forms, but for especially for EVEX.NDD forms variations might be possible.
j_agron
Thank you for the good question.
Existing zero idioms are preserved in the new APX encoding space (for both REX2 and EVEX prefix spaces).
More details will be available in the Software Optimization Manuals as APX-enabled platforms go public.
  • REX2
    • Existing legacy-space zero idioms (such as XOR reg, reg and SUB reg, reg) will naturally also exist in the REX2 map=0/1 space.  Signatures of the instructions aren't altered by the REX2 prefix, as there are no additional operands.
  • EVEX
    • Existing EVEX-space vector-based zero idioms aren’t affected by APX
    • New EVEX-space integer-based zero idioms that had analogues in the integer space will exist in the EVEX map=4 space (i.e. NDD = EVEX XOR reg, reg; and EVEX XOR reg reg, etc.).  Signature-wise, these are similar to existing EVEX-space zero idioms for vector registers (documented in the SOM), and the only difference is that the new EVEX forms can be applied to integer GPRs.
Beulich__Jan
Thanks for the reply. There's one problem there, though: Like in the manual you also mention only 2-operand instructions. Yet NDD ones take three operands, much like the relevant vector ones where the mnemonics start with V. Therefore saying "reg, reg" is insufficient. What is important to know is whether it is only the two sources which need to match, or whether all three registers (i.e. including the destination) need to be the same.
Correcting the manual in this regard would certainly also be nice.
j_agron
Hi, Jan.
Thanks -- yes, the SOM will be updated for existing idioms that are 3-operand, too, in the near future.
For integer idioms, a REX2-based idiom will always be quite a bit denser than an EVEX version - so that would be the recommendation from a code-density/perf perspective.  The EVEX version does provide some new capabilities (such as EVEX.nf).  The SOM update that includes idiom updates will clarify recommendations here, as well.
Beulich__Jan
Thanks. Since the recently published rev 050 doesn't have any update there, I'll leave marking this as resolved until (perhaps) rev 051 becomes available.
