16 bit unsigned images support in IPP
Ciro_R_
16 bits unsigned images are not very well supported by IPP: many functions work only with 8 bits unsigned and 16 bits signed images.
I would find functions with 16u arguments very useful. Are there other people interested in this kind of images?
Can I hope in an improved support of 16u images in the next releases of IPP?
Thank you very much
best regards
Ciro
Vladimir_Dudnik
Yes, this question ispopular enough. People everytime wants to have even more functionality, but could you please specify what functions you are interested more? It would also be useful to submit such request to Intel Technical Support channel.
Vladimir
Ciro_R_
thank you,
for many of the functionalities I need I can use 16s functions but it is not easy with histograms.
Best regards
Ciro
Vladimir_Dudnik
Ok, so, could you please submit your feature request to Intel Technical Support channels?
Vladimir
fzhang
Hi all,
Could please tell me which function can transform RGB data from 16u to 8u?
Fangming
Vladimir_Dudnik
Hi Fangming,
What do you exactly mean under convertion of 16 bit RGB data to 8-bit data? Is that about RGB565 to RGB888 convertion or just any 16-bit to 8-bit convertion?
I would recommend you to take a look on IPP documentation where you may find many useful information on IPP product.
Vladimir
