6847 Discussions
2022 Visual Studio IPP setvars.bat error: oneAPI toolkits no longer supports 32-bit libraries
eddie_patton
New Contributor II
Windows 11
IPP 2025
Visual Studio 2022
Visual Studio Code 1.92.3
When I run the IPP setvars.bat Developer Powershell in Visual Studio 2022 with this command:
`cmd.exe "/K" '"C:\Program Files (x86)\Intel\oneAPI\setvars.bat" && powershell'`
I get an error stating
ERROR: The oneAPI toolkits no longer support 32-bit libraries, starting with the 2025.0 toolkit release. See the oneAPI release notes for more details.
I figured out that this error occurs in this setvars.bat code
rem ===========================================================================
rem Override default 64-bit target if 32-bit Visual Studio env already exists.
rem Primarily affects "classic" compilers and some libraries (e.g., IPP, MKL).
if defined VSCMD_VER (
  echo: VSCMD_VER is defined.
  if /i [%VSCMD_ARG_TGT_ARCH%] == [x86] (
    echo :: ERROR: The oneAPI toolkits no longer support 32-bit libraries, starting with the 2025.0 toolkit release. See the oneAPI release notes for more details.
    echo: Error came from %VSCMD_ARG_TGT_ARCH%
    call :Usage
    goto :eofCleanup
  ) else (
    set TARGET_ARCH=intel64
I printed VSCMD_ARG_TGT_ARCH and it is "x86"
But when I ran commands to check of the powershell is 32 or 64 bit, I get the following on both Visual Studio and VS Code.
> [System.IntPtr]::Size
8
> $PSHOME
C:\Windows\System32\WindowsPowerShell\v1.0
According to google, the two above outputs say that the powershell is 64 bit.
In VS Code, the setvars.bat cmd completes without error.
So is this bug in setvars.bat?
Ruqiu_C_Intel
Have you checked VSCMD_ARG_TGT_ARCH value? It should be x64 for 64-bit
x86: Indicates that the target architecture is 32-bit x86.
x64: Indicates that the target architecture is 64-bit x64.
C:\Program Files\Microsoft Visual Studio\2022\Professional\VC\Auxiliary\Build>vcvarsall.bat x64
** Visual Studio 2022 Developer Command Prompt v17.12.3
** Copyright (c) 2022 Microsoft Corporation
[vcvarsall.bat] Environment initialized for: 'x64'
C:\Program Files\Microsoft Visual Studio\2022\Professional\VC\Auxiliary\Build>devenv
C:\Program Files\Microsoft Visual Studio\2022\Professional\VC\Auxiliary\Build>echo %VSCMD_ARG_TGT_ARCH%
x64
x64
C:\Program Files\Microsoft Visual Studio\2022\Professional\VC\Auxiliary\Build>"C:\Program Files (x86)\Intel\oneAPI\setvars.bat" && powershell
:: initializing oneAPI environment...
   Initializing Visual Studio command-line environment...
   Visual Studio version 17.12.3 environment configured.
   "C:\Program Files\Microsoft Visual Studio\2022\Professional\"
   Visual Studio command-line environment initialized for: 'x64'
:  compiler -- latest
:  debugger -- latest
:  dev-utilities -- latest
:  dnnl -- latest
:  dpcpp-ct -- latest
:  dpl -- latest
:  ipp -- latest
:  ippcp -- latest
:  mkl -- latest
:  mpi -- latest
:  ocloc -- latest
:  pti -- latest
:  tbb -- latest
:  umf -- latest
:  vtune -- latest
:: oneAPI environment initialized ::
Windows PowerShell
Copyright (C) Microsoft Corporation. All rights reserved.
Install the latest PowerShell for new features and improvements! https://aka.ms/PSWindows
PS C:\Program Files\Microsoft Visual Studio\2022\Professional\VC\Auxiliary\Build>
Ruqiu_C_Intel
x64
x64
:  dnnl -- latest
:  dpl -- latest
:  ipp -- latest
:  ippcp -- latest
:  mkl -- latest
:  mpi -- latest
:  ocloc -- latest
:  pti -- latest
:  tbb -- latest
:  umf -- latest
:  vtune -- latest
Windows PowerShell
eddie_patton
New Contributor II
That helped. I opened the command line window using Tools -> Command Line -> Developer Command Line.
When I specified x64,
C:\Program Files\Microsoft Visual Studio\2022\Community\VC\Auxiliary\Build>vcvarsall.bat x64
** Visual Studio 2022 Developer Command Prompt v17.9.5
C:\Program Files\Microsoft Visual Studio\2022\Community\VC\Auxiliary\Build>echo %VSCMD_ARG_TGT_ARCH%
x64
And then when running the command below, I got the same output as you.
