I created a dll created using the IPP function ippiFFTGetSize_C_32fc (). Referencing this dll file from wpf project (c #) results in "System.DllNotFoundException: Unable to load DLL 'TEST.dll'" error.
// C/C++ export.def
LIBRARY EXPORTS ippiFFTGetSize_C_32fc
// C/C++ dllMain.cpp
#define WIN32_LEAN_AND_MEAN
#include <windows.h>
#include "stdafx.h"
#include "HIOTEST.h"
#include "ipp.h"
BOOL WINAPI DllMain( HMODULE hModule,
DWORD ul_reason_for_call,
LPVOID lpReserved
switch (ul_reason_for_call)
case DLL_PROCESS_ATTACH:
ippInit();
break;
case DLL_THREAD_ATTACH:
case DLL_THREAD_DETACH:
case DLL_PROCESS_DETACH:
break;
return TRUE;
// C/C++ HIOTEST.h
#pragma once #include "ipp.h" #ifdef HIOTEST_EXPORTS #define HIOTEST_API extern "C" __declspec(dllexport) #else #define HIOTEST_API extern "C" __declspec(dllimport) #endif HIOTEST_API int HioTest(Ipp32fc* csSrcImg, Ipp32fc* csDstImg);
// C/C++ HIOTEST.cpp
#include "stdafx.h"
#include "ipp.h"
#include "ippi.h"
#include "ipptypes.h"
#include "ippcore.h"
#include "ippvm.h"
#include "ipps.h"
// FFT Init
IppiFFTSpec_C_32fc *pSpec = NULL; /* Pointer to FFT spec structure */
Ipp8u *pMemInit = NULL, *pBuffer = NULL; /* Pointer to the work buffers */
int sizeSpec = 0, sizeInit = 0, sizeBuf = 0; /* Size of FFT spec structure, init and work buffers */
int order = 9;
ippiFFTGetSize_C_32fc(order, order, IPP_FFT_DIV_INV_BY_N, ippAlgHintAccurate, &sizeSpec, &sizeInit, &sizeBuf);
return 5;
// C# (HIO_exe.sln)
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using System.Windows;
using System.Windows.Controls;
using System.Windows.Data;
using System.Windows.Documents;
using System.Windows.Input;
using System.Windows.Media;
using System.Windows.Media.Imaging;
using System.Windows.Navigation;
using System.Windows.Shapes;
using Microsoft.Win32;
using System.Runtime.InteropServices;
using System.Drawing;
using System.Numerics;
namespace HIO_exe
/// <summary>
/// MainWindow.xaml에 대한 상호 작용 논리
/// </summary>
public partial class MainWindow : Window
public struct CsIpp32fc
public float real, im;
[DllImport("HIOTEST.dll", CallingConvention = CallingConvention.StdCall)]
public static extern int HioTest(ref CsIpp32fc csSrcImg, ref CsIpp32fc csDstImg);
public string imgPath;
public Image origin = new Image();
public BitmapSource dstImg;
// FuctionWithIpp.dll Load
public MainWindow()
InitializeComponent();
private void OpenFile_Click(object sender, RoutedEventArgs e)
// file open
OpenFileDialog openDialog = new OpenFileDialog();
openDialog.InitialDirectory = @"C:\Desktop";
openDialog.Filter = "Image Files | *.jpg; *.png; *.tif; *.bmp; *.tiff";
openDialog.CheckFileExists = true;
openDialog.CheckPathExists = true;
if(openDialog.ShowDialog().GetValueOrDefault())
imgPath = openDialog.FileName;
BitmapImage bitmap = new BitmapImage(new System.Uri(openDialog.FileName));
SrcCanvas.Source = bitmap;
SrcCanvas.Width = tabBorder.Width;
SrcCanvas.Height = tabBorder.Height;
srcWidth.Content = bitmap.PixelWidth;
private void Run_Click(object sender, RoutedEventArgs e)
BitmapImage LoadBitMap = new BitmapImage(new System.Uri(imgPath));
int stride = LoadBitMap.PixelWidth;
int size = LoadBitMap.PixelHeight * stride;
byte[] srcImg = new byte[size];
LoadBitMap.CopyPixels(srcImg, stride, 0);
CsIpp32fc[] CsSrcImg = new CsIpp32fc[size];
CsIpp32fc[] CsDstImg = new CsIpp32fc[size];
for(int i = 0; i < size; i++)
CsSrcImg.real = srcImg;
// Error Point!!!
int res = HioTest(ref CsSrcImg[0], ref CsDstImg[0]);
// Error Point!!!
byte[] result = new byte[size];
result = (byte)CsDstImg.real;
dstImg = BitmapSource.Create(LoadBitMap.PixelWidth, LoadBitMap.PixelHeight, 300, 300, PixelFormats.Gray8, BitmapPalettes.Gray256, result, stride);
DstCanvas.Source = dstImg;
DstCanvas.Width = tabBorder.Width;
DstCanvas.Height = tabBorder.Height;
private void Save_Click(object sender, RoutedEventArgs e)
SaveFileDialog saveDialog = new SaveFileDialog();
saveDialog.InitialDirectory = @"C:\Desktop";
saveDialog.Filter = "JPeg Image|*.jpg|Bitmap Image|*.bmp|Gif Image|*.gif";
saveDialog.Title = "Save an Image File";
saveDialog.ShowDialog();
string saveFilePath = saveDialog.FileName;
using (var fileStream = new System.IO.FileStream(saveFilePath, System.IO.FileMode.Create))
BitmapEncoder encoder = new JpegBitmapEncoder();
encoder.Frames.Add(BitmapFrame.Create(dstImg));
encoder.Save(fileStream);
fileStream.Close();
I created a TEST.dll (C language) using IPP for External library. I want to refer to TEST.dll in my wpf project and use it.
The tool used is "visual studio 2017" and the IPP version uses the latest version of 'compilers_and_libraries_2019.1.144'.
See the IPP documentation. The settings of the dll project,
- Debug / x64
- Add "ippsmt.lib, ippcoremt.lib “ for 'Additional Dependencies' ".
- Automatic "single-threaded DLL" setting.
- 'export .def' created.
- Add ippInit () to dllmain.cpp
- Referencing from C # . /clr setting
C # project
- Debug / x64
- unlock the loader
- Increase the reserve stack size
I set it up like this.
Other ippMalloc (), ippsAdddC_32f_I ()
The dll file I created using the above worked properly in my wpf project. However, TEST.dll containing ippiFFTGetSize_C_32fc () will result in an error "System.DllNotFoundException: Unable to load DLL 'TEST.dll'".
I want to know the cause or solution.
I guess you've used "copy-past" for your question and several lines of your problem description are broken. Could you provide the full description of your problem?
regards, Igor
Thank you for pointing out my wrong question. Using the first question on the Intel forum, it was a lot lacking. Sorry.
I wrote down all the code for the two projects I wrote.
Hi Ku,
could you replace all references to IPP functions in your code with something like
printf("Hello world\n!");
What is happened in this case? just in order to be sure that something is wrong with IPP...
regards, Igor
