AAC - audio decoding and audio rendering
bharath322
I have tried to do AAC - audio streaming from the camera using the IPP audio-video codecs.
The following are the steps i have done.
1)
The initialization was done only once.
m_pAudioparams->m_info_in.sample_frequency = 8000;
m_pAudioparams->m_info_in.bitPerSample = 16;
m_pAudioparams->m_info_in.channels = 2;
m_pAudioparams->m_info_in.bitrate = 32000;
m_pAudioparams->m_info_in.stream_type = UMC::AAC_MPEG_STREAM;
m_pAudioparams->m_pData = rtspClient->m_pAudMediaIn;
// where m_pAudioparams is UMC::AudioCodecParams
if (UMC::UMC_OK = (m_pAudioDecoder->Init(m_pAudioparams)))
//initialization Sucess
2) Then
m_pAudMediaIn->SetBufferPointer((Ipp8u *)szData,len);
// m_pAudMediaIn is UMC::MediaData object ,szData is raw audio buffer from the camera i get everytime as it streams, len is length of the audio buffer.
m_pAudMediaIn->SetDataSize(len);
is set eveytime.
3)
UMC::Status stRes = m_pAudioDecoder->GetFrame(m_pAudMediaIn,m_pAudMediaOut);
if(UMC::UMC_OK == stRes)
if(!m_bFirst)
// Audio Renderer initialization is done only once
m_pAudioDecoder->GetInfo(m_pAudioparams);
m_bFirst =TRUE;
m_pAudioRenderParams->info = m_pAudioparams->m_info_out;
// At this point I got m_info_out.channels = 0,m_info_out.samplefrequency = 16000,m_info_out.bitrate = 0, m_info_out.bitpersample = 16,m_info_out.stream_type = PCM_AUDIO.
UMC::HWNDModuleContext hmcontext;
hmcontext.m_hWnd = (HWND)m_hWnd;
m_pAudioRenderParams->pModuleContext = &hmcontext;
UMC::Status stRes = m_pAudioRender->Init(m_pAudioRenderParams); //m_pAudioRender is UMC::WinMMAudioRender() HERE initialization is failing.
m_pAudioRender->SetVolume(1);
UMC::Status sta = m_pAudioRender->SendFrame(m_pAudMediaOut);
In this stepthe AACdecoder->getframe returns UMC::UMC_OK whenever it gets the frame.
I am having problem in initailizing the audiorender. It is failing.Could anyone please help me out where I am doing wrong?
Please reply.
