Access violation in ippsEncodeLZ77_8u
mickaelpic
Principiante
1.119 Visualizações
Hi, I am trying to use the compression IPPs to compress big files (~100MB)
But afterdeflating a few buffers I get an access violation in ippsEncodeLZ77_8u.
I tried to follow the operation description in zlib.h for deflate.
I would really like to understand what is wrong.
I use IPPss 5.3 Update 3 build 85.25, [5.3.471.85]
The following code isdeflating 3 buffers, (but stream.avail_out is always 2 after the first deflate, so I never get to write a single buffer to the output file)and then fails.
#define bufferSize 65536 // 64KB
#define aesBlkSize 32
inBuffer = (unsigned char*)ippMalloc(bufferSize);
if(inBuffer == NULL)
printf("Failed to initialize inBuffer ");
return -1;
outBuffer = (
if(outBuffer == NULL)
printf(
"Failed to initialize outBuffer ");
return -1;
stream.next_in = inBuffer;
stream.next_out = outBuffer;
stream.avail_out = bufferSize;
stream.avail_in = 0;
int toWrite = 0;
do
len = (
unsigned long)fread((char*)inBuffer, 1, bufferSize, fin);
stream.avail_in = len;
if(len > 0)
do
err = deflate(&stream, Z_NO_FLUSH);
if(err == Z_OK)
if(stream.avail_out < bufferSize)
toWrite = bufferSize - stream.avail_out;
// write the buffer
  ;if(fwrite((char*)outBuffer, 1, toWrite, fout) != toWrite)
printf(
"Failed to write to file ");
return -1;
else
if(Check_Error(err, "deflate") == -1)
return -1;
while(stream.avail_in != 0);
while(len != 0);
do
err = deflate(&stream, Z_FINISH);
if(err == Z_OK || err == Z_STREAM_END)
// write the buffer
if(fwrite((char*)outBuffer, 1, stream.total_out, fout) != stream.total_out)
printf(
return -1;
else
// Error
if(Check_Error(err, "Z_FINISH") == -1)
& nbsp;{
return -1;
while(err != Z_STREAM_END);
err = deflateEnd(&stream);
if(Check_Error(err, "deflateEnd") == -1)
return -1;
2 Respostas
mickaelpic
Principiante
1.119 Visualizações
Nevermind, I firgured it out.
I thought that next_in and next_outwould always point to the beginning of inBuffer and outBuffer.
So I just have to re-set them everytime I read/write from the buffer to the files.
Vladimir_Dudnik
Funcionário
1.119 Visualizações
Thanks for updating us on that issue!
Vladimir
Responder
