Affine transform produces invalid outputs
Goran_N
I am trying to implement this simple test program in IPP. It enlarges a sample 2d matrix by 200%. This is the Matlab version:
A = uint8([1 2 3; 4 5 6]) % Input matrix
tform = affine2d([2 0 0; 0 2 0; 0 0 1]); % Define transform
B = imwarp(A, tform, 'nearest') % Run the transform
I get this output, as expected:
A =
    1    2    3
    4    5    6
B =
    1    1    2    2    3    3
    1    1    2    2    3    3
    4    4    5    5    6    6
    4    4    5    5    6    6
This is IPP equivalent code:
// ipptest.cpp : Attempt to use WarpAffine to scale an image 200%.
#include "ipp.h"
#include <iostream>
#include <iomanip>
typedef unsigned char byte;
int main(int argc, char* argv[])
 ippInit();
 // Source image and ROI
 static const int kHEIGHT = 2;
 static const int kWIDTH = 3;
 byte srcImage[kHEIGHT][kWIDTH] =
  { 1, 2, 3 },
  { 4, 5, 6 }
 IppiRect srcRoi;
 srcRoi.x = srcRoi.y = 0;
 srcRoi.width = kWIDTH + 1;
 srcRoi.height = kHEIGHT + 1;
 IppiSize srcSize;
 srcSize.height = kHEIGHT;
 srcSize.width = kWIDTH;
 // Destinatino image buffer and ROI
 byte destImage[kHEIGHT * 2][kWIDTH * 2];
 IppiRect destRoi;
 destRoi.x = destRoi.y = 0;
 destRoi.width = kWIDTH * 2 + 1;
 destRoi.height = kHEIGHT * 2 + 1;
 // Scale source image by 200% in both x and y
 double coeffs[2][3] =
  { 2.0, 0.0, 0.0 },
  { 0.0, 2.0, 0.0 }
 IppStatus stat;
 double bound[2][2];
 // Following code is from AffineTransform sample to figure out destination width and height
 stat = ippiGetAffineBound(srcRoi, bound, coeffs);
 double width = bound[1][0] - bound[0][0];
 double height = bound[1][1] - bound[0][1];
 std::cout << "IPP sample says " << kWIDTH << " x " << kHEIGHT << " image should be scaled 200% to " << width << " x " << height << std::endl;
 // Print input image
 std::cout << std::endl << "Source image: " << std::endl;
 for (int row = 0; row < kHEIGHT; ++row)
  for (int col = 0; col < kWIDTH; ++col)
   std::cout << " " << (unsigned int)srcImage[row][col];
  std::cout << std::endl;
 // Apply transform
 stat = ippiWarpAffine_8u_C1R(
  (const Ipp8u*)srcImage, srcSize, kWIDTH, srcRoi,
  (Ipp8u*)destImage, kWIDTH * 2, destRoi,
  coeffs, IPPI_INTER_NN);
 // Print output image
 std::cout << std::endl << "Transformed image: " << std::endl;
 for (int row = 0; row < kHEIGHT * 2; ++row)
  for (int col = 0; col < kWIDTH * 2; ++col)
   std::cout << " " << (unsigned int)destImage[row][col];
 return 0;
But what I get is this:
IPP sample says 3 x 2 image should be scaled 200% to 6 x 4
Source image:
 1 2 3
 4 5 6
Transformed image:
 1 2 2 3 3 204
 4 5 5 6 6 204
 4 5 5 6 6 204
 204 204 204 204 204 204
Press any key to continue . . .
Obviously the transformed image isn't correct. Can somebody point out what's wrong, please.
Valentin_K_Intel
Hi Goran,
Which version of Matlab is used?
To check the transformation I implemented the following small test for Matlab.
tform=maketform('affine',[2 0 0; 0 2 0; 0 0 1]); % Define transform
B = imtransform(A, tform, 'nearest') % Run the transform
I got this result:
A =
    1    2    3
    4    5    6
B =
    1    2    2    3    3
    4    5    5    6    6
    4    5    5    6    6
Regards, Valentin
Goran_N
OK, I see, I get the same output when I run your version, so Matlab and IPP match.
But could you please explain why if I have a 2x3 matrix and enlarge it by 200% I get 3x5 output instead of 4x6.
Wouldn't it make sense that using [2 0; 0 2] linear transform matrix would double the size of the input matrix?
Thanks!
Valentin_K_Intel
Thank you for the question. The matrix represents the image, where each pixel is a point that has own color value and (x,y) coordinates. Pixel coordinates correspond to the position of the number in the matrix. So if we have MxN matrix then the left-top point has coordinates (0,0) and the right-bottom point has coordinates (N-1,M-1). When we double increase the matrix size, we obtain a new matrix with the left-top point (0,0) and the right-bottom point ( (N-1) * 2, (M-1) * 2 ). In case of 2x3 matrix the right-bottom point has coordinates (x,y) = ( (3 - 1)*2 , (2 - 1)*2 ) = (4, 2), therefore the size of the enlarged matrix is 3x5.
Regards, Valentin
Goran_N
Thanks for the explanation!
