Am I running AES-NI?
James_Wei
Can someonehelp meto confirmthat the following y8 codes exerciseall seven AES-NI, namely AESENC, AESENCLAST, AESDEC, AESDECLAST, AESKEYGENASSIST, AESIMC, and PCLMULQDQ?
0000000000404520 :
00000000004047ac :
0000000000404a38 :
0000000000404b50 :
0000000000404c78 :
0000000000404c90 :
0000000000405ac8 :
0000000000405cf0 :
0000000000405d70 :
0000000000406030 :
0000000000406e9c :
00000000004070d0 :
000000000040715c :
000000000040746c :
0000000000407a8c :
00000000004080ac :
0000000000415290 :
00000000004158c0 :
00000000004160a0 :
0000000000416670 :
00000000004166fc :
00000000004167d0 :
0000000000416930 :
0000000000416bd0 :
0000000000416d20 :
0000000000416ed0 :
Chao_Y_Intel
Y8 code are possibly for SSE4.1, SSE4.2 and AEI-NI(Westmere processors).
You can try the following function with ippCPUID_AVX flag to check the if AVX is enabled in the processors.
ippGetCpuFeatures(Ipp64u* pFeaturesMask, Ipp32u pCpuidInfoRegs[4]);
Chao
PaulF_IntelCorp
Hello James,
Engineering has provided the following answer.
Whole set ofRijndael processingfunctions uses AES-NI.
In IPP implementations are not use AESKEYGENASSIST, AESIMC instructions, because IPP focused on performance processing basically.
So all other AES-NI, namely AESENC, AESENCLAST, AESDEC, AESDECLAST and PCLMULQDQ are used in implementation of the following AES modes: ECB, CBC, OFB, CFB, CTR, CCM and CGM
Implementation of Rijndael192andRijndael256kernels (i.e basic encryption and decryption algorithms)is based on AES-NI too.
The following public entry points are descending to AES-NI based code
- ippsRijndael128{Encrypt|Decrypt}{ECB|CBC|CFB|OFB|CTR|}
- ippsRijndael128CCM{Encrypt|Decrypt},ippsRijndael128CCM{Encrypt|Decrypt}Message
- ippsRijndael128GCMProcess{IV|AAD}, ippsRijndael128GCM{Encrypt|Decrypt},ippsRijndael128GCM{Encrypt|Decrypt}Message (PCLMULQDQ is here)
- ippsRijndael{192|256}{Encrypt|Decrypt}{ECB|CBC|CFB|OFB|CTR|}
One may take a look at map file and find functions with _AES_NI suffixes. It's internal functions holding AES-NI.
Paul
