6841 Discussions
BUG! UMC::FileReader does not work correctly with files larger than 2GB in 32bit applications.
anonymous210
In the umc_file_reacer.cpp there are expression like:
m_iOff + m_pDataPointer - m_pBuffer
but that is not correct. The correct expression is
m_iOff + (m_pDataPointer - m_pBuffer)
For example consider the following code from FileReader::OpenView(Ipp64s iSize) :
Ipp64s iPos = m_iOff + m_pDataPointer - m_pBuffer;
if
m_iOff = 0x800000FF;
m_pDataPointer = NULL;
m_pBuffer = NULL;
and the code is compiled in 32bit mode
then
return a value iPos = 0xffffffff800000ff. This is not correct!
but
Ipp64s iPos = m_iOff + (m_pDataPointer - m_pBuffer);
return a value iPos = 0x800000ff. This is correct!
Thank you.
PaulF_IntelCorp
Thank you for identifying that bug and posting the solution. I will make sure our engineering group is notified so that this fix can be incorporated in future releases of the UMC sample code.
Paul
PaulF_IntelCorp
This bug has been marked as implemented in the 7.0 library release.
Paul
