Basics of video and audio decoding
r3d
I have read the forums and tried to understand fully the "simple player" that comes with ipp and I would like to know if my ideas about decoding video(and audio) are correct.
For decoding video I execute the following loop(after intiializing the avi splitter , the video decoder and the video render).
UMC::Status DecodeMPEG4Video()
out.SetVideoParameters(spl_info.m_video_info.clip_info.width,
spl_info.m_video_info.clip_info.height,
UMC::RGB24);
umcRes = genVideo->LockInputBuffer(&out);
umcRes = avi_spl.GetNextVideoData(&in);
while (umcRes == UMC::UMC_NOT_ENOUGH_DATA && in.GetDataSize() < 10000)
out.SetTime(in.GetTime());
if (umcRes == UMC::UMC_OK)
umcRes = mpeg4_dec.GetFrame(&in, &out);
if(umcRes == UMC::UMC_OK)
umcRes = genVideo->UnLockInputBuffer(&out);
if (umcRes != UMC::UMC_OK)
return umcRes;
umcRes = genVideo->RenderFrame();
return umcRes;
return umcRes;
} // DecodeMPEG4Video()
It works ok with divx mpeg4 codec, but It shows Jittering(back and forward frames) problems with xvid. So, I have doubts about the procedure and would be glad to be pointed out to the right way
1)Lock the buffer(out) and get data in the UMC::MediaData variable in with GetNextVideoData until I have enough data(which value I am supposed to check with in in.GetDataSize() < ? )
2)Then I set the time of UMC::VideoData out variable with in.GetTime().
3)Next I decode the frame(forced mpeg4 in this example) mpeg4_dec.GetFrame
4)Unlock the buffer and do the RenderFrame
I do more or less similar things with audio with a UMC::DualThreadedCodec. The audio decoding loop scheme is something like
1)The audio decoder is initialized and a MediaBuffer given(UMC::LinearBuffer) with some UMC::MediaBufferParams. Then while not enough data GetNextAudioData in audio_in UMC::MediaData variable
2)Lock a mediaData buffer
dual_treaded_codec.LockInputBuffer(&buff)
3)Memcopy the audio_in buffer in buff being the data to copy the min between audio_in dataSize and buff BufferSize (with GetDataSize and GetBufferSize calls)
4)Unlock buff
5)Decode the audio data with dual_treaded_codec.GetFrame and put it in a UMC::AudioData variable
I get sound with this, but it gets some jitter(forward/backward jumps).
Thanks in advance!
Borja Morales
r3d
Up, any little suggestion about this please smiley [:-)] ?
Vladimir_Dudnik
might be the reason is your stream? Can you attach it for analysis?
Vladimir
r3d
Hi Vladimir:
It's not the stream because (I forgot to say) the same video works ok ith the simple Player. That's Why I asked If I was doing something wrong with the way I get the nexdata, the buffers or similar. Do you think the procedure I wrote is correct?
Thanks!
