Binarizing an image via thresholding
monarckmills
Hi, the search function is messed up and unusable, so I am creating a new topic without being able to search for a similar thread.
 I want to simply binarize a 8bit single channel (gray) image with a threshold. Eg. pixels >= 128 will be set to 255, other pixels (which are <  128) will be set to 0.
None of the ipp thresholding functions seem to work for this. Closest one is Threshold_LTValGTVal which does not accept 128 and 127 as the thresholdLT and thresholdGT values. It says thresholdGT must be >= thresholdLT, which leaves the pixels equal to the threshold as is, if I set both of them to 128.
I believe binarizing an image over a single threshold is a very common operation and I don't want to to aritmetic operations or thresholding twice to achive such a simple task. What am I missing?
Update: the reason i dont want to use arithmetic operations, eg. divide by 128 to binarize is :
uint8_t testimg[8] = {1, 126, 127, 128, 129, 139, 254, 255};
uint8_t testout[8] = {0};
ippiDivC_8u_C1RSfs(testimg, 8, 128, testout, 8, IppiSize{8, 1}, 0);
// testout: [0 1 1 1 1 1 2 2]
Adriaan_van_Os
Yes, I have stumbled over the limitations of the IPP threshold functions too. But for 8u and 16u, the alternative is to use ippiLUTPalette.
Adriaan van Os
Adriaan_van_Os
And in this specific case you could also try ippiReduceBits.
Adriaan van Os
Igor_A_Intel
Hi Adriaan van Os,
IppStatus ippiCompare_<mod>(const Ipp<datatype>* pSrc1, int src1Step, const
Ipp<datatype>* pSrc2, int src2Step, Ipp8u* pDst, int dstStep, IppiSize roiSize,
IppCmpOp ippCmpOp);
Supported values for mod:
8u_C1R 16u_C1R 16s_C1R 32f_C1R
8u_C3R 16u_C3R 16s_C3R 32f_C3R
8u_C4R 16u_C4R 16s_C4R 32f_C4R
This function compares the corresponding pixels of ROI in two source images pSrc1, pSrc2 using the
ippCmpOp compare operation, and writes the results to a one-channel Ipp8u image pDst. If the result of the
compare is true, the corresponding output pixel is set to an IPP_MAX_8U value; otherwise, it is set to 0.
regards, Igor
Igor_A_Intel
Sorry, copy-pasted wrong reference - you should use compare operation with const value:
IPPAPI (IppStatus, ippiCompareC_8u_C1R,(const Ipp8u* pSrc, int srcStep, Ipp8u value,
                                        IppiSize roiSize,  IppCmpOp ippCmpOp))
regards, Igor
Adriaan_van_Os
Igor,
Yes, thanks, that works in the example case given above.
But now for another example. Suppose I have two threshold values A and B where A <= B, Suppose I want to give all pixels where pixel =< A or pixel >= B a specific value. I call ippiThreshold_LTValGTVal. So far, so good. But what IPP function to call if I want to give all pixels where A < pixel < B a specific value ?
Adriaan van Os
monarckmills
regards, Igor
Hi Igor, thank you! This is what I was missing.
Igor_A_Intel
Hi Adriaan van Os,
regarding Threshold_LTValGTVal - for your use case there should be developed one more API - something like Threshold_LTValGEVal. We'll consider this new API for future versions.
regards, Igor
