Bug in ippiGrayErodeBorder
Adriaan_van_Os
The IPP Developer Reference documents that the border parameter of the functions ippiGrayErodeBorder_8u_C1R and ippiGrayErodeBorder_32f_C1R accepts ippBorderRepl as the only type of border.
However, for application threading (which is what Intel wants us to do, for mysterious reasons) ippBorderRepl must be combined with a mask of ippBorderInMemTop, ippBorderInMemBottom, ippBorderInMemLeft and ippBorderInMemRight, depending on the location of the tile to be processed. But when ippBorderRepl is combined with ippBorderInMemTop, ippBorderInMemBottom, ippBorderInMemLeft or ippBorderInMemRight, ippiGrayErodeBorder_8u_C1R and ippiGrayErodeBorder_32f_C1R return errror ippStsBadArgErr (=-5).
Consequently, ippiGrayErodeBorder can not be application-threaded.
Now that we are at it, I wonder why there is no ippiGrayErodeBorder_16u_C1R variant.
Adriaan van Os
Gennady_F_Intel
which version of ipp are you talking about?
Adriaan_van_Os
I checked version IPP 9.0, 2018-2 and the bug fix notes. There is no mentioning that this would have been fixed since.
Adriaan van Os
Adriaan_van_Os
Same problem with ippiFilterWiener. This function doesn't even have an IppiBorderType parameter. Consequently, no ippBorderInMem mask can be passed for individual tiles. And therefore ippiFilterWiener can not be application-threaded.
Adriaan van Os
Igor_A_Intel
Hi Adriaan van Os,
ippiFilterWiener is based on ROI concept and therefore can be easily application-threaded. ROI concept assumes that all required for operation pixels are available in the memory - therefore it is default implementation of the Border In Mem. The staring point of Wiener filtering operation is calculated as
    strtSrc = (Ipp8u*)pSrc - ( mask.height - anchor.y - 1 ) * srcStep - ( mask.width - anchor.x - 1 );
 for 8u_C1R image/block/chunk/tile.
regards, Igor
Adriaan_van_Os
Igor,
With all respect, that doesn't work.
(1) If we set the ROI size to be an exact (un-enlarged) tile of the image, on the seams of the tiles it will be visible that there is no Wiener Filtering at the edges of the tiles;
(2) If we set the ROI size to be enlarged at the in-memory sides of the tiles, we have concurrent access of several threads to the same data; which is a recipe for disaster.
Adriaan van Os
Adriaan_van_Os
Sorry, you are right, I withdraw my previous comment.
Adriaan van Os
Adriaan_van_Os
Igor,
OK, tiling for ippiFilterWiener works. Still, for large kernel sizes (say 39), is ippiFilterWiener an approximation or exact ? And how could it be so fast if it is exact ? The ippiFilterWiener function doesn't seem to be completely size-independent in all cases.
Adriaan  van Os
Igor_A_Intel
Hi Adriaan van Os,
ippiFilterWiner is implemented absolutely in the same way as in Matlab.
regards, Igor
Adriaan_van_Os
I will reimplement the WienerFilter, compare the results and get back.
Adriaan van Os
