Bug in ippsPhase_64fc
Eyal_L_
I have found a bug in ippsPhase_64fc,
where should I report it?
Zhen_Z_Intel
Dear Customer:
You could report the problem here. Could you tell me what's version of IPP you are using, how about your system environment & what kind of error (error message) you are facing? and could you also provide a test case if possible that we could reproduce. Thanks.
Fiona
Eyal_L_
This is the code that crashes on Ipp version 2017.0.098
#include <ipp.h>
char data[] = {0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xF0, 0x7F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xF0, 0x7F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xF0, 0xFF, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xF0, 0xFF, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xF0, 0x7F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xF0, 0x7F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xF0, 0xFF, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xF0, 0xFF, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xF0, 0x7F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xF0, 0x7F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xF0, 0xFF, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xF0, 0xFF, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xF0, 0x7F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xF0, 0x7F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xF0, 0xFF, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xF0, 0xFF, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xF0, 0x7F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xF0, 0x7F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xF0, 0xFF, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xF0, 0xFF, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xF0, 0x7F, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xF0, 0x7F};
void crash() {
  Ipp64f phases[11];
  ippsPhase_64fc((Ipp64fc*) data, phases, 11); // change to 12 and it doesn't crash
int main() {
  crash();
  return 0;
Igor_A_Intel
Hi Eyal,
Could you be more specific - please add 2 more lines of code and provide an output, please:
    const IppLibraryVersion* lib;
    lib = ippsGetLibVersion();
printf("major = %d\n",lib->major);
printf("minor = %d\n",lib->minor);
printf("majorBuild = %d\n",lib->majorBuild);
printf("build = %d\n",lib->build);
printf("targetCpu = %s\n",lib->targetCpu);
printf("Name = %s\n", lib->Name);
printf("Version = %s\n", lib->Version);
printf("BuildDate = %s\n", lib->BuildDate);
I've tried your example on Win32 and don't see any issues - so I need OS, arch, static or dynamic linking, mt or st, etc. - this all info will be clear from the ippsGetLibVersion()
regards, Igor
Eyal_L_
It is linux 64bit
The output is:
major = 2017
minor = 0
majorBuild = 0
build = 52494
targetCpu = y8
Name = ippSP SSE4.2 (y8)
Version = 2017.0.0 (r52494)
BuildDate = Jul 16 2016
Eyal_L_
dynamic linking
Zhen_Z_Intel
Dear customer,
I could reproduce your problem by using g++ compiler, but no error with icc compiler. We will investigate on it. Thanks.
Fiona
Zhen_Z_Intel
Hi Eyal,
Thanks for posting bugs of IPP. We will fix this problem in new release.
Fiona
