CMake configuration for static dispatching?
wombat
I am linking statically IPP to my project using CMake. I basically do:
// CMakeLists.txt
set(IPP_SHARED OFF)
find_package(IPP REQUIRED)
target_link_libraries(myapp PRIVATE ${IPP_LIBRARIES})
and then
// myapp.c
#include <ipp.h>
And this is fine.
However, I want to use static dispatching as I have the luxury to know the target hardware:
// myapp.c
#include <ipp_e9.h>
This doesn't work as `ipp_e9.h` is not in the include paths returned by the `IPP` package. What configuration should I use to enable it?
ShanmukhS_Intel
Thanks for your patience. This is to kindly inform you that currently, we don't provide paths to static dispatcher header files as part of cmake configuration files.
As a workaround, instead of using the full path, one could use ${IPP_ROOT_REL_PATH}/opt/ipp/tools/intel64/staticlib for IPP2021.10 and $ENV{IPPROOT}/tools/intel64/staticlib for previous releases.
Could you please check and let us know the updates?
Shanmukh.SS
ShanmukhS_Intel
Hi Pascal,
Could you please get back to us with the OS details and IPP version being used by you? Could you please get back to us with a sample reproducer? It helps us reproduce the issue at our end and guide you in resolving the same.
Shanmukh.SS
wombat
OS is Windows 10.
IPP version is 2021.9.0.
A sample would look like below.
// main.cpp
#include <ipp_e9.h> // fails here; OK if commented
#include <ipp.h>
int main() { return 0; }
// CMakeLists.txt
cmake_minimum_required(VERSION 3.21)
project(foo)
add_executable(foo main.cpp)
set(IPP_SHARED OFF)
target_link_libraries(foo PRIVATE ${IPP_LIBRARIES})
ShanmukhS_Intel
Thanks for sharing the details.
We are looking into your issue internally. We will get back to you soon with an update.
Shanmukh.SS
ShanmukhS_Intel
Hi Pascal,
Could you please try adding the line to your CMakeLists.txt as mentioned below and run make and let us know if the issue persists?
include_directories(<add the include directory which contains the requires header file>)
For Ex: include_directories(/opt/intel/oneapi/ipp/2021.9.0/tools/intel64/staticlib)
Shanmukh.SS
wombat
I could, however how do I find the correct path from within CMake, so that the solution is portable?
ShanmukhS_Intel
Hi Pascal,
A gentle reminder:
Has the information provided helped? Could you please let us know if the issue persists?
Shanmukh.SS
ShanmukhS_Intel
Hi Pascal,
In your CMakeLists.txt file, use find_package() to locate Intel IPP. You are expected to specify the desired IPP version and component(s) you want to use or you could use find_library() to locate the static library: After finding IPP, you can use find_library() to locate the static library you want to link.
Could you please try these and let us know if you need any help?
Shanmukh.SS
wombat
I don't understand, the static library is already found by `find_package`.
Can you provide a working example based on the code you asked me?
ShanmukhS_Intel
Hi Pascal,
Could you please elaborate on your issue? In your CMakeLists.txt file, you could use find_package() to locate Intel IPP.
A Sample CMake:
cmake_minimum_required(VERSION 3.16.3)
project(foo)
set(IPP_SHARED OFF)
Intel® Integrated Performance Primitives (Intel® IPP) installs in the subdirectory referred to as <ipp directory> inside <install_dir>. By default, the <install_dir> is:
  • admin:/opt/intel/oneapi
  • user:~/intel/oneapi
You could refer to the Linux OS section under the below link to find Intel IPP and more details on your system.
https://www.intel.com/content/www/us/en/docs/ipp/developer-guide-oneapi/2022-2/finding-intel-ipp-on-your-system.html#LINUX
find_package(Package Name)
Package Name: Here you need to input the name of the package you want to find. Make sure it corresponds to a CMake module or script that provides the package's configuration information.
Shanmukh.SS
wombat
You already proposed to hardcode the path to the library (here), but as I answered (here), I am looking for a portable solution, so that anybody could configure and compile the project without having to know where IPP is installed on their system.
Is there a way to achieve that? Or are portable CMake projects using IPP restricted to dynamic dispatching? It seems to me, seeing you struggling with this as I am, that this possibility has not been taken into account by the maintainers of IPP's CMake configuration scripts.
ShanmukhS_Intel
Shanmukh.SS
ShanmukhS_Intel
A gentle reminder:
Has the information provided helped? Could you please let us know if you need any other information?
Shanmukh.SS
ShanmukhS_Intel
Thanks for accepting our solution. If you have any other queries, please feel free to raise a new thread.
Shanmukh.SS
