CPU Usage Problem for FIR Filter.
dolsei0
Hi..
I am executing a C++ code implemented using IPP,for repeat FIR filtering 640*480 times for 512 data.
While executing code on 2way Xeon Quad CPU ( = 8 core), the CPU usage is just 12%.
Just one cpu works.
What is my mistake ?
My system is like this.
Xeon E5320 Quad - 2 way : 8 Core
Windows Server 2003 R2 x86
IPP : 5.3.3
IPP Dynamic Link Library
Visual Studio 6.0 + Intel Compiler 10.1
int nTotalPixel = m_ImageSizeX * m_ImageSizeY;
int i;
int k;
int len = m_nImage;
IppsFIRState_32f* pState;
IppStatus st;
Ipp64f* taps = ippsMalloc_64f(tapslen*sizeof(Ipp64f));
Ipp32f* taps_32f = ippsMalloc_32f(tapslen*sizeof(Ipp32f));
Ipp32f* pSrc = ippsMalloc_32f(len*sizeof(Ipp32f));
Ipp32f* FIRDst = ippsMalloc_32f(len*sizeof(Ipp32f));
Ipp32f* pDL = ippsMalloc_32f(tapslen*sizeof(Ipp32f));
ippsZero_32f(pDL,tapslen);
// COMPUTES TAPSLEN COEFFICIENTS FOR BANDPASS FIR FILTER..
ippsFIRGenBandpass_64f( LowFreq, HighFreq, taps, tapslen, ippWinHamming, ippTrue);
ippsConvert_64f32f(taps,taps_32f,tapslen);
// INITIALIZE FIR FILTER..
ippsFIRInitAlloc_32f(&pState,taps_32f,tapslen, pDL);
BYTE *pImageBuffer;
for(i= 0; i < nTotalPixel; ++i)
pImageBuffer = &m_pImageBuffer[i*m_nBuffer];
//GENERATE SOURCE VECTOR
ippsConvert_8u32f(pImageBuffer,pSrc,len);
// FILTER AN INPUT VECTOR
ippsFIR_32f(pSrc, FIRDst, len, pState);
ippsAddC_32f_I(128.,FIRDst,len);
ippsConvert_32f8u_Sfs(FIRDst,pImageBuffer,len,ippRndNear,0);
ippsFIRFree_32f(pState);
ippsFree(pSrc);
ippsFree(FIRDst);
ippsFree(taps);
ippsFree(taps_32f);
ippsFree(pDL);
Vladimir_Dudnik
IPP internally estimates size of data to process and turn on threading only when it gives performance gain.
Vladimir
dolsei0
Thank for your reply.
I just try to FIR Filter for just 512 data.
And repeat this same job 640 * 480 times.
Under this operation, I don't understand that IPP cannot surpport the multi thread..
Vladimir_Dudnik
Do you expect library should launch 8 threads to process 64 elements of data in each?
Are you aware of the cost for thread launch? It takes between 2000 and 3000 processor clocks.
Vladimir
dolsei0
Oh~
I understand your reply. Thank you for your reply.
Then, does it help to repeat this job using OPENMP,
because IPP function use only one cpu.
Vladimir_Dudnik
If you can filter your image with 2D FIR then you may consider to call ippiFIR filter function. Of course it is possible to launch threads on top of IPP. You may use OpenMP threading or any other threading API.
Vladimir
