CPU requirements for MPEG-4 Video Encoding
hnhoan
Can anyone tell what would be the CPU requirements to Encode MPEG-4 video at D1 resolution (720x480) 30fps? With Linux embedded OS. Can a PIII 1GHz do the job ? I need to be used with Fanless CPU. Thanks
daveabrams
I'm *very* interested in what you are working on.
A small, compact, no-fan, PIII, embedded Linux that does IPP MPEG-4 encoding is exactly what I've been looking for.
Let me know how your project goes.
The only metrics that I've seen are
MPEG-2 on a P4 at 3Ghz does 300 frames/second at 720x480 pixels.
daveabrams
I'm sorry, decode is 300 fps, encode is 75 fps.
Intel_C_Intel
We measured the performance of MPEG4 encoder onPentium-III 750 MHz
Source 720x480 100 frames YUV 4:2:0 from hard disc (data is cashed in memory)
MPEG-4 encode parameters - Fast Motion Estimation, IntPel ME Accuracy, 1 Motion Vector per MacroBlock, I and P frames only (no B)
Performance - 18
.2 fps
Vladimir
