6847 Discussions
Cache usage for a DSP program implemented with IPP
block1
I am currently building a real-time multiprocessor scheduling algorithm that will preempt
tasks and move them between processors frequently. One of our biggest concerns is that
there will be a serious cache hit whenever a task moves between processors. Our target application
is a DSP program, and as is my understand such programs typically have a small cache footprint. I was wondering, if we were to move our DSP program over to the IPP, how large would the cache footprint be?
Thanks for the help,
Aaron
Vladimir_Dudnik
Hi Aaron,
I think it is not related to IPP directly. You can write program which work with memory in efficient way with or without using IPP. Generally speaking, you should reduce each task memory requirement to not allow one taskloadallcache memory.
Vladimir
