Can IPP libraries be used with clang on ubuntu
maupadhy
I was trying to compile a library which uses IPP using clang compiler (10.0) on ubuntu (20.04 LTS) machine. Is this combination supported?
I'm not seeing clang compiler in supported compiler list for linux distributions.
PraneethA_Intel
Hi Manish,
Thanks for posting in Intel communities.
At present Clang compiler is not supported for IPP in Linux. For a list of other compilers you can use that are supported by Intel IPP, please see the below link.
https://www.intel.com/content/www/us/en/developer/articles/system-requirements/intel-integrated-performance-primitives-intel-ipp-2020-system-requirements.html
We would like to inform you that Intel DPC++ compiler/ C++ Compiler supports both Windows and Linux operating systems. It’s built on LLVM and uses the Clang front end, and SYCL 2020 standards to support C++, and OpenCL kernels through the same source file. Please refer to this link for more details.
Thanks and Regards,
Praneeth Achanta
maupadhy
Hi @PraneethA_Intel ,
Is there any way to do so OR is there any plans to support it in near future.
Thanks for replying.
maupadhy
Installed OneAPI on ubuntu (20.04 LTS) machine.
I was able to compile my project using clang  compiler and link with IPP libraries (libippdc.a,libippi.a,libipps.a,libippvm.a,libippcore.a).
Should't I get linking error if clang is not supported?
Also My library is functioning, though performance is degraded as compare to library built with gcc. Why so?
PraneethA_Intel
Hi Manish,
The list of IPP-supported libraries is given here. As informed earlier, Intel Compilers are built using Clang front end, and since IPP libraries are binary, it might work for other compilers, but these are not officially tested and will have to be verified by the users individually.
Currently, there is no specific timeframe for when support for Clang would be added. Support for new compilers will be in our future release plan.
Thanks and Regards,
Praneeth Achanta
PraneethA_Intel
Hi Manish,
We have not heard back from you. Could you please let us know if the information provided helped?
Thanks & Regards,
Praneeth Achanta
PraneethA_Intel
Hi Manish,
We hope the information provided helped. As we have not heard back from you, this thread will no longer be monitored by Intel. If you need further assistance, please post a new question.
Thanks and Regards,
Praneeth Achanta
