Can't find file ipps.lib (but IPP is disabled)
superstatic
Hi guys.
I have a VS2010 solution using Parallel Studio in which I have disabled IPP under properties->intel performance libraries ("Use IPP") for each project but the linker is still telling me it can't find ipps.lib.
Any idea what might be causing this?
Thanks a lot!
Chao_Y_Intel
Are you using Parallel Studio 2011? Please check the following two settings:
1) Does the code include any IPP head filer (e.g ipp.h), and project prosperity>>C/C++>>Preprocessors>>Preprocessor Definitions include definition like '_IPP_PARALLEL_DYNAMIC, If so, please remove it.
2) In project prosperity>>Linker>> Input>>Additional Dependencies, does it include any IPP libraries?
Chao
superstatic
Thanks for the quick reply. Yeah, it's Parallel Studio 2011 which I'm using in Visual Studio 2010. I don't have these things set. I've just taken my existing project and selected "Use Intel" on the solution without making any additional changes.
I just turned off "Enabled Multiply Matrix Call" (which was set to yes by default) and this let 4 out of the 16 projects in the solution build successfuly. I have no idea why the others keep asking for ipps.lib.
Ma
Chao_Y_Intel
Would it be posssible to attach a sample project, so we can have a check?
Chao
Naveen_G_Intel
Reason could be because of linking library is not pointing to right directory. It should be
/Composer/IPP/lib/ia32
I was getting same error while running IPP sample with IPS 2011, working after setting right path as mentioned above.
Naveen Gv
