Cannot find crypto library
Ahmet_Balci
I'm using Ubuntu 12.04 and Eclipse. As I try to use crypto libraries, I get the error:
cannot find -l/opt/intel/composer_xe_2011_sp1.9.293/ipp/lib/intel64/libippcp.so
And yes I have added that library from Paths and Symbols.
Thx
Ahmet
Chao_Y_Intel
Ahmet, Have you found that /opt/intel/composer_xe_2011_sp1.9.293/ipp/lib/intel64/libippcp.so is already in the folder? Also, it looks "-l" is not needed if you add full library name. Thanks, Chao
Ahmet_Balci
Chao, Of course it is already in the folder, because I have selected the library and added to libraries in Paths and Symbols. Also, I didn't write "-l" there, eclipse did. It was on the console as an error. Thanks for the reply, Ahmet
