Choosing the correct EM64T Library files ...
matoos80
Hello all,
I can flawlessly compile IA-32 versions of my IPP 5.0 based code using the command line c++ compiler 9.0. But it's a different story for EM64T. How do I determine which of the many em64t library files to use?
Here is my current command-line command:
icl /O3ippsemergedem64t.lib ippsmergedem64t.lib ippcoreem64t.lib
I am getting linker errors like this:
IPP41_FFTc.obj : error LNK2019: unresolved external symbol t7_ippsWinBartlett_32
f_I referenced in function "int __cdecl bench(int,int,int,int,int,int,int,int,ch
ar *,int,__int64 *,int * const)" (?bench@@YAHHHHHHHHHPEADHPEA_JQEAH@Z)
IPP41_FFTc.obj : error LNK2019: unresolved external symbol t7_ippsSum_32f refere
nced in function "int __cdecl bench(int,int,int,int,int,int,int,int,char *,int,_
IPP41_FFTc.obj : error LNK2019: unresolved external symbol t7_ippsMalloc_32fc re
ferenced in function "int __cdecl bench(int,int,int,int,int,int,int,int,char *,i
Where IPP41_FFTc.cpp is my file containing the code calling IPP functions.
Any advice on getting around these linker errors?
Matoos
Ying_S_Intel
Dear Customer,
With linking with Intel IPP static library with dispatch, you may also add this call before any IPP function calls: ippStaticInit();
If you think the IPP EM64T staticl ibrary with dispatch does not work in 5.0 beta, please report it to our Intel Premier Support for further investigation.
Ying S
Intel Corp.
